towing 6000lbs camper
Old Mar 11, 2008 | 06:28 PM
gunthet's Avatar
gunthet
i said this before but i think i used defrent forum would like to know if i can tow a 6000lbs camper with 2001 f150 4.6 3.55 .i have power programmer ,exhaust,heavyduyt shocks and addtnl leaf springs. i now tow 5000lbs camper and it does good
Old Mar 11, 2008 | 07:32 PM
elmo8641's Avatar
elmo8641
what tranny do you have, 4x4 or 2x4, regular cab supercab?
Old Mar 11, 2008 | 07:36 PM
elmo8641's Avatar
elmo8641
depending what setup you have changes the tow capacity greatly. ranges from 2,900lbs for a supercab 4x4 with a standard trans to 7,200 with a 2x4 regular cab auto tranny. but if you tow 5,000lbs now and don't have any problems then i think you should be ok with a extra 1,000lbs. not a huge increase.
Old Mar 11, 2008 | 08:12 PM
gunthet's Avatar
gunthet
4x4 supercab
Old Mar 11, 2008 | 08:18 PM
elmo8641's Avatar
elmo8641
what tranny?
Old Mar 11, 2008 | 08:19 PM
gunthet's Avatar
gunthet
auto tarnny
Old Mar 11, 2008 | 08:29 PM
gunthet's Avatar
gunthet
thank you elome8641
Old Mar 11, 2008 | 08:41 PM
elmo8641's Avatar
elmo8641
your truck is rated for either 6,100lbs or 6,600lbs. there is 2 listed and all it says is 16" or 17". i don't know if that is rim size or not. if so then if you have 16" rims then it is 6,600 if 17" rims then 6,100. either way you should be alright.
Old Mar 11, 2008 | 08:55 PM
gunthet's Avatar
gunthet
have 16'' but do you think with heavyduty shochs and addtny leafsprings towing camp is more
Old Mar 11, 2008 | 09:13 PM
gunthet's Avatar
gunthet
i am new to this do i have to see new email ever time to see reply
Old Mar 12, 2008 | 03:38 PM
elmo8641's Avatar
elmo8641
legally your tow rating will never change. but with the upgrades it will handle it better.
Old Mar 12, 2008 | 04:53 PM
kappysworld's Avatar
kappysworld
Here is what I found out about the F150
The models are:
Tenth generation (1997–2003)
F-150: 1/2 ton (6,600 GVWR max)
F-250: 1999 3/4 ton (7,700 GVWR max)
F-250 Super Duty: 3/4 ton
F-350 Super Duty: 1 ton (11,200 GVWR max)
F-450 Super Duty: 1 1/4 ton chassis-cab only
F-550 Super Duty: 1 1/2 ton chassis-cab only (19,000 GVWR max)
F-650 Super Duty: oversized commercial truck cab (26,000 GVWR max)
F-750 Super Duty: oversized commercial truck cab (33,000 GVWR max)
Engines:
1997-2003 - 4.2 L Essex V6, 202 hp (151 kW)/252 ft·lbf
1997-1998 - 4.6 L Triton V8, 220 hp (164 kW)/280 ft·lbf
1999-2003 - 4.6 L Triton V8, 231 hp (172 kW)/293 ft·lbf
1995-1998 - 5.4 L Triton V8, 235 hp (175 kW)/330 ft·lbf
1999-2003 - 5.4 L Triton V8, 260 hp (194 kW)/350 ft·lbf
1999-2000 - 5.4 L supercharged Triton V8, 360 hp (99-00 Lightning)
2001-2004 - 5.4 L supercharged Triton V8, 380 hp (01-04 Lightning)
1999-2004 - 5.4 L supercharged Triton V8, 340 hp (02-03 Harley-Davidson)
1999 - 6.8 L Triton V10, 275 hp (205 kW)/410 ft·lbf (Super Duty only)
2000-2003 - 6.8 L Triton V10, 310 hp (231 kW)/425 ft·lbf (Super Duty only)
1999-2003 - 7.3 L Power Stroke turbo-Diesel V8, 250 hp (186 kW)/525 ft·lbf (Super Duty only)
2003-2004 - 6.0 L Power Stroke turbo-Diesel V8, 325 hp (242 kW)/560 ft·lbf (Super Duty only)
http://en.wikipedia.org/wiki/Ford_F-Series
Old Mar 12, 2008 | 05:51 PM
gunthet's Avatar
gunthet
thanks for the info guys think am going to buy the new camper. keep it as light as i can. i do not go very far win camping
Old Mar 14, 2008 | 09:30 PM
gunthet's Avatar
gunthet
got the camper rides beter then the old one
Old Mar 15, 2008 | 06:11 AM
jowilker's Avatar
jowilker
Imagine that!
John
