Ping/knock 351M
Old Aug 24, 2001 | 04:14 PM
beartracks's Avatar
beartracks
Ping/knock 351M
OK, I would use a spray bottle or a baster. Rev it up a little maybe 1500 rpm and slowly start adding water untill the engine starts to slow down a little. Don't get too carried away or you could cause a hydralic lock in the motor. Probably be better if the engine is good and warm. If you get black smoke out the back keep going till it clears up. I'd use up to a quart for a session. I'm not shure if this will get it all buts its supposed to work well. When your done you can look in #1 cylinder at the top of the piston and at the plug. Crank the piston up to TDC and shine a light in there. Maybe even scrape it with a thin piece of wood so you can see what you got.
Good luck,
Bear Tracks
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Aug 25, 2001 | 12:07 AM
jopey's Avatar
jopey
Ping/knock 351M
Ok spray bottle it is. now should it be a fine mist or stream?
Old Aug 25, 2001 | 02:57 AM
cobrajet's Avatar
cobrajet
Ping/knock 351M
and make sure you put a new set of spark plugs in after you do the steam cleaning with the water. all that carbon is going to cake up on the plugs. atleast look at them this way you know there won't be a mysterious miss after you get done. C.J. ....
Old Aug 25, 2001 | 02:26 PM
beartracks's Avatar
beartracks
Ping/knock 351M
Keep giving it water till it bogs down. Add water and throttle. You don't want to add enough to kill it but you want it be noticable slowing the motor. I think this will clean the plugs too but you need to look at them all to see if one is broken/eroded away.
1977 Ford F-100
280,000 miles
Old Aug 26, 2001 | 01:22 AM
Bull's Avatar
Bull
Ping/knock 351M
Jimmy Pet
Modular V10 (6.8l)
127
Aug 4, 2019 01:21 PM
Eric K
Modular V10 (6.8l)
126
Apr 20, 2008 12:35 AM
Shawn MacAnanny
Feb 21, 2007 10:27 AM
jbabbler
3.0L V6
Jan 7, 2005 10:02 PM
RangerXLT89
4 Cylinder Engines
Dec 27, 2004 09:22 AM
