Sponsored by: Auxito
EVAP problem
Old Mar 11, 2008 | 04:19 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
EVAP problem
cant remember the number but i keep getting a code everytime i start the truck.... it says evap circut malfuntion.... where is the evap circut board on these, i think its up by the engine somewhere.
Old Mar 11, 2008 | 04:27 PM
Silver Streak's Avatar
Silver Streak
There is no EVAP circuit board. That just means that there is an open or short circuit somewhere in the evap system. Could be as simple as an unplugged component or as complicated as a broken or shorted wire buried in the most inaccessible place on the truck.
Old Apr 1, 2008 | 09:12 PM
RacerLT250R's Avatar
RacerLT250R
the evaporative emmissions system includes the charcol canister and soleniod back by the spare tire and i believe the gas cap also. I think leaving the gas cap off will give you a evap code....I have a evap code also and have replaced the soleniod and the gas cap and check wiring and more wiring and cant get it to go away. I;m going to try replacing the canister but haven;t had the time yet.....i'll let you know if i have any luck
Old Apr 2, 2008 | 06:35 AM
pbutland's Avatar
pbutland
I continuously got EVAP codes. Can't remember the code. May be 1504 ? Not sure. The problem was I was overfill the gas tank with fuel. During a fill up I would always try to round off to the dollar. Some reason or other I would get a check engine line approximately 50 miles down the road. I know stop when the pump shuts off. Not more check engine light.
Old Apr 2, 2008 | 07:05 AM
projectSHO89's Avatar
projectSHO89
There are about a dozen different EVAP codes possible with a LOT of possible faults.
Until we have the EXACT fault code(s), it is not particularly useful to speculate on what may be causing the fault lamp to come on.
Steve
Old Apr 2, 2008 | 07:37 AM
BURNSTOUGHFORD
The code reads evap circut malfunction.... i already looked it up...
Old Apr 2, 2008 | 07:53 AM
Silver Streak
The problem is that there are several circuits and several ways to fault each one. We need the code number to help you, not what a code readers offers as a description.
Old Apr 2, 2008 | 10:38 AM
BURNSTOUGHFORD
i have the code, but im pretty sure ive nailed it, im going to swap out the canister for another one.
Thanks for the help guys
mfp4073
1983 - 2012 Ranger & B-Series
May 7, 2015 10:25 PM
bullfisher
Jan 21, 2011 07:48 PM
bicyclemonkey
Sep 23, 2009 01:07 PM
Bob O GomA
Sep 25, 2004 09:10 PM
R6elmo
Jun 11, 2004 08:32 PM
