351M vs 400M
Old Aug 22, 2001 | 12:45 PM
jopey's Avatar
jopey
351M vs 400M
When the day comes and I need to replace the 351M I am thinking going to a 400M. The only question I have is will the 400 emit more pollution @ the smog station than the 351 does?
The 400 will be stock except for a high quality aftermarket oil pump. I just would not have the space to do a complete engine build up, so my best bet is a remanufactured engine.
Old Aug 22, 2001 | 01:20 PM
beartracks's Avatar
beartracks
351M vs 400M
I would think the 400 would do just as good if not better. It's a percentage thing and not volume I believe.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Aug 22, 2001 | 01:22 PM
jopey's Avatar
jopey
351M vs 400M
Will the 400 offer much of a power increase?
I do know it has a longer stroke. and more cubes equal more torque.
but will I feel it in the seat of my pants type?
Thanks for the info!
Old Aug 22, 2001 | 06:43 PM
Boss_358's Avatar
Boss_358
351M vs 400M
It depends on how you build it. From my personal experiences and opinion is that the 400 is a better engine than the 351M, especially for trucks. I have seen some of these engines putting out some nice power.
People who say it can't be done should not interrupt the person doing it.
Old Aug 22, 2001 | 07:06 PM
jopey's Avatar
jopey
351M vs 400M
I will not rebuild it myself. No time to do so. but swapping the motor out will be done by me.
I would like to replace the pan wiht something with more capaticity, and a better quaility oil pump. Also maybe some nice looking chrome valve covers, 4 barrel intake. but I would have to swap these to pass emmissions here in CA
Old Aug 23, 2001 | 10:40 AM
jopey's Avatar
jopey
351M vs 400M
Would the 400 get pretty much the same MPG as the 351M?
Everything else is the same correct? all the ignition parts will bolt up and work just fine?
I seen in another post someone said the 400 had a bigger clutch than the 351? will my fly wheel work on the 400?
I do know I need a new harmonic balancer!
Old Aug 23, 2001 | 06:43 PM
Boss_358's Avatar
Boss_358
351M vs 400M
The 400 has a 12" clutch and the 351M has an 11". All ignition parts and external components are identical, or at least compatable. I don't know if your flywheel will work, but I know that question was answered in another post.
Old Aug 24, 2001 | 02:41 PM
bigeric's Avatar
bigeric
351M vs 400M
In stock form, both of these engines are pretty lame. My brother put a fresh 400 in his '78, which previously had a 351m. The 400 has plenty of low-end torque, but everything's over by 4,000 rpm, if not before. There's really not much point in revving it past 2000 rpm. As for gas mileage, he didn't notice any difference. And he switched from a 2v carb on the 351 to a 4v on the 400.
it seems to me that that link to the 400 buildup article that gets kicked around here every once in a while discusses how to get big power out of the 400 while keeping it emissions-friendly. I know the builders were under some constraints as far as emissions went; not sure if they were in CA or not. But I guarantee you will be disappointed in the 400's power output if you were expecting a big difference from the 351. At least set your cam timing straight up and look into higher compression pistons or milling the heads.
Old Aug 24, 2001 | 02:45 PM
jopey's Avatar
jopey
351M vs 400M
I am not expecting to go from a 4 banger's power to a bigblock.
I was just wondering what I would probably see as far as increases.
I have also read that tech write up on the "M" series.
Old Aug 26, 2001 | 04:03 PM
bigeric's Avatar
bigeric
351M vs 400M
Well, according to factory specs for 1978 pickups, the 400 has about four more hp than the 351m but makes considerably more torque at lower rpm--roughly 300@1600 rpm, if memory serves. So it might be worth it if you tow with your truck.
Old Aug 26, 2001 | 04:05 PM
jopey's Avatar
jopey
351M vs 400M
I basically use it as a daily driver. and it is a bronco. So wheeling is also a favorite of mine.
so more bottom end torque is what I want. but I want to stay within the emissions of CA.
Old Aug 28, 2001 | 12:36 AM
bigeric's Avatar
bigeric
351M vs 400M
Also, you should be able to put your old clutch, flywheel, etc on your 400. I think they came with a bigger clutch from the factory, and a bigger radiator, for that matter, but I think it's because these bigger motors came only in 3/4 tons from the factory and were expected to do heavy work.
Old Aug 28, 2001 | 07:11 AM
bbtkd's Avatar
bbtkd
351M vs 400M
[ENDQUOTE]
A lot of them went in Rancheros and I believe some went in larger cars too (LTDII and possibly Thunderbird and some Lincolns). They are one helluva motor though. I'm tempted to take my 351 CJ (4V) heads and build myself a 400CJ. The 400 ought to be able to keep the port velocity up on the 4V heads without losing any low-end torque. Weiand intake spacers can be 'ported' so an aftermarket 351 4V intake can be used. Anyone done this?
Tom
Old Aug 28, 2001 | 05:30 PM
danlee's Avatar
danlee
351M vs 400M
Tom[/QUOTE]
I have a 400C-4V in my '53 F100. I have no problems with port velocity, but mine is a cruiser not a work vehicle. I am using an Edelbrock Performer Intake and a 750 CFM Carter carb. The CR with flattop pistons and open chambered (62.8cc) heads is about 10.3:1. That makes 92 Octane pump gas marginal. The other consideration is that the Weiand spacers raise the position of the intake manifold so your stock distributer will not fit. I am using a Mallory Unilite dist, to my knowledge that is the only one that will fit.
Dan Lee
'53 F100
400C-4V
Old Aug 29, 2001 | 02:22 PM
ecarter50's Avatar
ecarter50
351M vs 400M
Jacob Federow
Mar 15, 2017 04:43 PM
1977F250highboy
Aug 30, 2016 01:20 PM
SWDinehart
Nov 24, 2014 07:58 PM
jf77
Apr 28, 2012 12:32 PM
mirage820
Jul 30, 2004 03:32 AM
