Sponsored by: Auxito
Hissing Noise
Old Mar 11, 2008 | 07:56 AM
bowdog's Avatar
bowdog
Hissing Noise
Hey Guys:
Noticed when I was changing the oil the other day that when I turn my truck off, there is a hissing or tinging noise coming from the driver side engine compartment. I looked around and saw no leaks, Any ideas what it may be? I have a 98 F150 4x4 4.6.
Thanks
Bowdog
Old Mar 11, 2008 | 09:05 AM
projectSHO89's Avatar
projectSHO89
Try to pinpoint the source while it is making the noise.
Old Mar 11, 2008 | 09:32 AM
ground_zero298's Avatar
ground_zero298
Mines been doin that for years, nothing has ever come from it. I figered it's just built up air in the cooling system.
Joe Finn's Avatar
Joe Finn
I think the noise you're talking about is normal. Mine does it too. I always thought it was "left over" vacuum in the heat / AC controls, but I don't know for sure.
Old Mar 11, 2008 | 09:49 AM
bowdog's Avatar
bowdog
thanks guys....I wasn't sure what it was....it has me stumped...I do know that there are no fluids leaking anywhere. just an annoying sound that alerts you to a potential problem.
I will monitor it and see if anything comes of it
Happy Trucking!!!!!
Bowdog
Old Mar 11, 2008 | 10:12 AM
Club Wagon's Avatar
Club Wagon
Was the "hissing or tinging noise" new? Now that you've "noticed" it does it happen every time?
You can eliminate "left over vacuum in the heat / AC controls" OR "built up air in the cooling system" & check for other sources. To dump vacuum press the brake pedal several times until the vacuum reserve is used up. To eliminate AC refrigerant noises turn the AC compressor off (OFF, FLOOR or PANEL) & leave it off for awhile (overnight to be certain, but an hour should do) before listening for the sound.
A "tinging noise" is normal on my '98 F150 4X4 4.6 but is the common sound of exhaust system cooling.
bowdog
1997 - 2003 F150
Mar 11, 2013 09:39 PM
bowdog
1997 - 2003 F150
Nov 8, 2009 07:42 PM
bowdog
1997 - 2003 F150
13
Aug 30, 2009 12:45 AM
bowdog
Feb 12, 2009 02:06 PM
bowdog
1997 - 2003 F150
Feb 7, 2008 10:13 AM
