Ignition cylinder lock relpacement
Old Mar 10, 2008 | 06:41 PM
Darthmookie's Avatar
Darthmookie
No, I'm not trying to get you guys to help me jack a truck.
I bought a 95 F-250 auto w/7.3 liter diesel on the weekend. Got it for a song. It has 2 problems however. I need to sort out problem #1 before I can move on to problem #2.
First, it has no key. The previous owner died in an auto accident and his widow couldn't find the key. She knows that he had one on his keychain that he had when he was in his accident, but that vehicle was a writeoff and they took the whole thing to the wreckers. Keys and all. As for a spare, she has no idea. Someone else had tried getting it going and made a mess of the key slot so I think cylinder replacment is in order. Does anyone have a walkthrough of the procedure for changing one out? Pictures would go miles and miles towards helping me out.
Problem # 2 - At last report, the truck wouldnl't go in reverse. But I need to get it home before I can look at that.
Old Mar 10, 2008 | 07:40 PM
PhantomRider's Avatar
PhantomRider
I don't know about the 95's but i have an 87 that i replaced the cylinder on. I disconnected the battery and turned the key to the "RUN" position. There is a small hole in the column shroud underneath and a little to the left of the cylinder. I think i used a small nail in that hole to depress the retaining pin and the cylinder slid out.
As far as not going into reverse, there is an actuator rod that runs from the cylinder to the ignition switch on top of the steering column underneath the dash. I've had that actuator rod break before and get wedged where i couldn't shift at all. In your case it may be that or something else like a linkage problem.
I don't know how similar the m87 and 95 are but i hope this helps!
Old Mar 10, 2008 | 07:54 PM
TGO's Avatar
TGO
This was just covered a couple of days ago on this forum.
Click on the link, if this doesn't help I will take pictures for you.
https://www.ford-trucks.com/forums/forum28/index3.html
Old Mar 10, 2008 | 08:28 PM
Darthmookie
Thanks! I tried the search function first and came up with 285 threads. This forum moves one hell of a lot faster than the ones I'm used to.
freeranger
2015 - 2020 F150
19
Mar 13, 2022 05:28 PM
lowcountry
2004 - 2008 F150
Oct 25, 2009 11:06 AM
d_stange
36
Jun 21, 2006 06:41 AM
83 F350
Jan 12, 2004 12:55 AM
