garage floor
Old Mar 10, 2008 | 06:27 PM
newblder's Avatar
newblder
garage floor
I have made one heck of a mess of my garage floor. Between the mustang and the f3 I'm afraid I might have ruined it with oil and other fluid spills. Does anybody have any suggestion on what to use to clean it? Has anybody ever used U Coat it or something like it?
Old Mar 10, 2008 | 06:52 PM
WALFORD'S 56's Avatar
WALFORD'S 56
You can buy a concrete cleaner at any hardware store. The concrete has to be clean before any epoxy coatings anyhow. Or clean it and put cardboard under the truck and problem solved. TIP in Canfield,Ohio sells a absorber for oil,etc and I use one for all my trucks............Bill
Old Mar 10, 2008 | 07:16 PM
newblder's Avatar
newblder
Thanks for the info. I'm selling the house and moving in about a year so I'm going to start working on getting in ready to put it up for sale.
Old Mar 10, 2008 | 07:25 PM
ALBUQ F-1's Avatar
ALBUQ F-1
TSP (tri-sodium posphate) is good at leaching the oil out of the concrete, and won't actually eat it up like acids. Just mix up a strong batch and keep it soaking for a while, let it soak in, then flush. Purple cleaner is good too but costs more.
Old Mar 10, 2008 | 07:51 PM
e william's Avatar
e william
Try muratic acid. My spelling may be a little off....you can get it at most hardwares and Lowes, etc... Follow directions, be careful with it (ITS ACID).
It's fairly inexpensive and used to clean concrete and such. Rinses with water.
Ed
Old Mar 10, 2008 | 08:03 PM
55 f350's Avatar
55 f350
FTE Remembers
muratic acid is also good for cleaning the crap outta your aluminum so it can be repolished !!!!!!! used it all the time on the large cars .
Old Mar 12, 2008 | 03:30 AM
newblder's Avatar
newblder
What about floor coatings? Has anyone had any luck with any of those? U Coat it seems really expensive to me. If there is somewhere that sells something just as good for less, I'd rather not spend the money.
Old Mar 12, 2008 | 05:36 AM
Walston's Avatar
Walston
I always clean the floor up with cat litter first, it absorbs any "free oil" and if you scrub the floor with it lots of time it cleans it up completely.
I coated my floor when I built it with a concrete sealer, it helps but the oil still stains somewhat.
Old Mar 12, 2008 | 11:39 AM
Jag Red 54's Avatar
Jag Red 54
I bought the epoxy coating at Home Depot. It comes with a cleaner (acid) and color flecks. It turned out real well. Jag
Old Mar 12, 2008 | 07:10 PM
newblder's Avatar
newblder
Thankfully my wife just got rid of her cat (haha) so I have some cat litter. Thanks for the info. I'll have to check out Home Depot when I get back.
