Tailgate chains
Old Mar 10, 2008 | 01:51 PM
Joker50's Avatar
Joker50
Tailgate chains
I ordered a set of chrome tailgate chains for my 1950 F-1. Upon arrival, I noticed that the chrome chain bracket which attaches to the truck is a bit different. My original chains attached at the rear of the truck and at the top of the stake pocket with one bolt. The chrome chains attach to the side of the stake pocket with 3 bolts. This can done very easily but don't the bolts restrict my use of the stake pocket? At the present time, I really have no plans for using the stake pockets but I do not want to drill holes if they are not needed. Have any of you encountered the same issue?
Joker50
Old Mar 10, 2008 | 07:19 PM
dongc1's Avatar
dongc1
I was given a set of chains that attach like the ones you bought. I decided not to use them and put on some latches. What did the chains cost? I want to sell mine, but I don't know what they are worth.
Thanks,
Old Mar 11, 2008 | 06:53 AM
Joker50's Avatar
Joker50
Smile Tailgate Chains
The chains are LMC part #40-3147 and costs 69.95. Good Luck!
Joker50
Old Mar 11, 2008 | 07:40 AM
going slow's Avatar
going slow
hey joker can u split a link and re-attach it to your old set up ?
Old Mar 11, 2008 | 07:56 AM
49willard's Avatar
49willard
I also have a set of those SS chains (note that LMC calls them chrome-mine are not magnetic so therefore SS) that I plan to use. Willard is a 49 and I have the earlier raised side bed. The SS chains that I have are made for the later flat sided beds (changeover occuring in 1950). I want my chains inside the bed rather than outside so I plan on a number of mods to the tailgate/chains and a different latch system. I have not done it yet.If you use the chains outside (which I have considered) on the earlier beds and want to use the original rivoted bracket I would cut/modify the appropriate SS chain link open it up, pass it through the original bracket and weld it back closed. If it is SS you will need to TIG it. A fair amount of hassel to save the stake pocket.
Old Mar 11, 2008 | 08:55 AM
Joker50's Avatar
Joker50
Good idea to split the chain link. I just may do that when I get to that part of the rebuilding stage.
Joker50
JeffLee
16
Dec 14, 2017 10:37 AM
JP78F100Truck
Dec 24, 2014 11:47 AM
JeffLee
Jul 31, 2012 05:29 PM
fordmantpw
2004 - 2008 F150
Jan 7, 2006 09:12 AM
laynrubber
Jul 21, 2005 04:20 PM
