Help!!!!
Old Mar 10, 2008 | 07:38 AM
Rockstar1985's Avatar
Rockstar1985
Exclamation Help!!!!
Hello,
I'm recently new to the forums.Having a little trouble with my truck this morning>First off i paid $800 for this truck 2 years ago and to today have never so much as turned a wrench on it.It is a 91 f-150 lariat,5.0 v-8 and when i went to crank it this morning white smoke started coming out from under the hood and the ground wire on battery was smoking.Well i knowcked it off the battery and it made a loud POP!It burned a hole in my battery right under negative post and smoked the rubber off the ground wire?I'm not a mechanic so what should i do??Replace ground wire i know.But do i need a new battery too??HELP!!!
Old Mar 10, 2008 | 07:48 AM
wizzard351's Avatar
wizzard351
if the bat is leaking id get one. it should be tested anyway befor ya hook it all back up
Old Mar 10, 2008 | 07:51 AM
Rockstar1985
not leaking from what i can see.ole is on top...right next to post almost
Old Mar 10, 2008 | 08:00 AM
Rockstar1985
still dont know what to do...kinda stuck here guys...n e suggestions??
Old Mar 10, 2008 | 09:56 AM
Rockstar1985
i think i figured out the problem....short in wiring...where can i get a wiring diagram for my make and model??
