charging
Old Mar 8, 2008 | 07:08 PM
deeznuts822's Avatar
deeznuts822
charging
I seem to be having abnormal readings on my 88 ford in the last few days usually the guage is a lil above half with headlites and heat on but now it starts out good when u first start it for day but as it warms up goes below half and goes even lower when heats goin... So my question is regulator or alt.
Old Mar 8, 2008 | 07:25 PM
baldboyford's Avatar
baldboyford
Could be either, a quick check for the alt is to use a voltmeter on the battery while the truck is running. If the voltmeter reads 13.8-14V give or take a tenth of a volt or two, then the alt is probably ok. This is not a full proof test for the alt, but it is a good indicator.
Old Mar 8, 2008 | 08:27 PM
4x2mudder's Avatar
4x2mudder
if you have a neighborhood advanced auto parts. im pretty sure they will test your battery and alternator for free. if not you may be able to go to a store like checkers or walmart and probably get them tested for a small fee
Old Mar 10, 2008 | 10:28 AM
deeznuts822
turned out to be a broken ground strap to motor.
