Missing Miss.....
Old Oct 7, 2001 | 07:42 PM
fordkid's Avatar
fordkid
Missing Miss.....
My 79 Shortbed has a miss in it somewhere, cant seem to nail it. Actually im not totally positive that its a miss, but under load at about 1200 to 2000 rpm it shakes really bad, and throuhgout the rpm range it lacks torque. I know the 351m's and 400's enough to know that you shouldnt have to downshift into third from fourth the make it up a rinky dink hill. Also starting out in second you gotta beat it or itll stall. I've had 3 different carbs on it, new plat. plugs, dist. cap. rotor, air filter, and i run it on 91 octane. It has Accel plug wires on it that are about 2 yrs old. I cant seem to find any vac leaks or anything unusual. Please help me out before I get a little temper wild. Thanks, Mike
________________________________________
It's not what you buy, it's what you build.
1996 Explorer, minor detailing
1979 F150 Shortbox 351M 4 spd. 4x4
1978 F250 Supercab 351M Big cam 30k miles
1977 F150 351M 4spd 4x4 4" lift outrageous cam and a bunch of other goodies
http://ourworld-top.cs.com/KrystalMeth2000/index.htm
Old Oct 7, 2001 | 11:00 PM
Franklin2's Avatar
Franklin2
Missing Miss.....
Time for a compression check of the cylinders I think.
Old Oct 8, 2001 | 12:22 PM
beartracks's Avatar
beartracks
Missing Miss.....
Maybe the EGR plate under the carb is eaten up inside and leaking vacuum.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Oct 9, 2001 | 06:46 AM
Chuck P.'s Avatar
Chuck P.
Missing Miss.....
Might want to check the diaphram in the dist. for leaks, also make sure nothing came loose inside, springs, ect. Sounds like it might not be getting enough advance.
Old Oct 11, 2001 | 09:36 PM
fordkid's Avatar
fordkid
Missing Miss.....
Well I tested all of my plug wires everything seems fine and dandy, my EGR plate is all good, I just had that off and cleaned it up and eliminated the EGR valve and slapped on a plate. So I think a compression test is coming next. If that doesnt bring up anything bad ill have to get myself a vac gauge. I dont know why I bother though, another motor is goin in next week anyways....yeah well. It'll make me feel better to hear it run right one time. Thanks guys.
Old Oct 11, 2001 | 10:39 PM
bubbaf250's Avatar
bubbaf250
Missing Miss.....
bpete
Dec 12, 2015 07:53 PM
rsm688
30
Jun 16, 2015 09:25 AM
GrossPapi
21
Sep 4, 2013 09:06 AM
824x4ride
Offroad & 4x4
Oct 24, 2003 05:02 AM
fordkid
Mar 6, 2002 07:31 PM
