Valve Adjust
Old Oct 14, 2001 | 09:20 AM
Zs514rd's Avatar
Zs514rd
Valve Adjust
Have 1972 351C 2V just want to know, do the lifters just bolt on or is there some adjustment to be done.
I've done 289-302's before this is my first 351C.I was told by the guy I got it from that he just "bolted them on and they worked fine".
Thank You
Z
Old Oct 14, 2001 | 02:53 PM
Franklin2's Avatar
Franklin2
Valve Adjust
Yes, the rocker arms just bolt on.
Old Oct 16, 2001 | 08:43 AM
335clevo's Avatar
335clevo
Valve Adjust
Yeah you're right, they are hydraulic lifters. Need no adjustment, just keep them clean and oiled and DON'T mix the order up if you have to take them out,
335C
Old Oct 17, 2001 | 08:28 AM
Christian's Avatar
Christian
Valve Adjust
This may be a little pedantic, but my service & repair manual gives these specific adjustments regarding to Cleveland rockers:
1) Rotate the engine til No. 1 cylynder is at t.d.c. on the compression stroke and install the rockers on exhaust valve Nos. 1, 3, 7, and inlet valve Nos. 1, 4, 8.
2)Rotate crankshaft 180 degrees.
3) Install the rockers for exhaust valve Nos. 2,6 and inlet valve Nos. 3 and 7.
4) Rotate the crankshaft a futher 90 degrees.
5) Install rockers on exhaust valve Nos. 4, 5, 8 and inlet valve Nos. 2, 5, 6.
6) Check that all fulcrum bolts are tightened to a torque of 23 ft/lb
The book describes how you adjust for valve lash, but basically that is done by using 0.060 or 0.060 shorter pushrods (which were available from Ford).
I'm guessing that you would only go to this trouble if you were making a race engine or similar.
Old Oct 20, 2001 | 12:31 PM
nick1's Avatar
nick1
Valve Adjust
william16339
Oct 21, 2016 10:17 AM
Supercab
Apr 19, 2016 02:07 PM
chad.deraps
Oct 12, 2012 11:22 AM
bigolebluef150
Nov 20, 2006 03:09 PM
rexx
13
Dec 12, 2002 04:17 PM
