crossover steering
Old Mar 9, 2008 | 08:15 PM
P3aflyer's Avatar
P3aflyer
crossover steering
Couldn't find what I needed searching for this info.
I have a 74 4x4Crewcab that I put a 1ton steering box on. Can any one tell me what is the simplest way to do a cross over steering system on this setup?? Should I use an 86 or later f350 arms or have some made?
or use the 3inch spacer on the opposite knuckle and have a drag link made?
Broncograveyard has some interesting setups..
Whatcha think??
Old Mar 9, 2008 | 08:19 PM
P3aflyer's Avatar
P3aflyer
oh, forgot to mention that I have a dana 60 open knuckle front end.. my tie rod is new but does not have the hole in it for a drag link ect.. I would replace the tie rod with whatever setup would work best for a crossover system.
Old Mar 9, 2008 | 09:58 PM
73 ford guy's Avatar
73 ford guy
Does the front axle have kingpins??
Old Mar 9, 2008 | 10:28 PM
P3aflyer's Avatar
P3aflyer
Yes on the king pins,
I was considering just getting a new tie rod and then a long drag link, but it does not look like it would clear the spring.. The drag link on the newer, 95 and forward trucks, looks like it would work because it has a bend in it..
Anyone tried the newer drag links?
Old Mar 9, 2008 | 10:38 PM
73 ford guy
get a draglink custom made and mount it to a arm on the passenger side kingpin
Old Mar 9, 2008 | 10:41 PM
73 ford guy
I have that 1 ton steering box too but I went with a 2wd model because it is longer and gives a better draglink angle with a drop pitman arm
Old Mar 9, 2008 | 11:13 PM
P3aflyer's Avatar
P3aflyer
very strange???
I was just checking out your gallery,, and looked at your setup,, visited NWFW website and made a note to call them tomorrow..
I am glad you posted here.. How do you like the setup?
Did you have the drag link made or is it a custom link made by them?
one more question did you make the sway bar??
Thanks again
Old Mar 9, 2008 | 11:18 PM
P3aflyer's Avatar
P3aflyer
Ya I went with the four bolt box and a 3 inch drop pittman. It looks like it would work well.
I will have to measure for the drag link.. it would be a WAG since I don't have the knuckle yet, but if I get within an inch or so that should work.. It looks like they want 169 for the knuckle and 85 for the drag link..
Old Mar 10, 2008 | 12:04 AM
73 ford guy
I ordered the complete kit from them. They first sent me the steering arm,drop pitman, and rod ends.Onlything left out was draglink bar. Then I bolted everything in place so I could make the measurement of the draglink they made. Its the only way to go for steering way better push pull design. The steering arm can be used for high steer as well(relocating tie rod above leaf spring for clearance over rocks ect..) Yeah I made the trac bar its to help prevent bumpsteer and side to side movement.
Old Mar 10, 2008 | 02:10 AM
Slow's Avatar
Slow
I keep looking at all these threads because I want to do the same thing. However, I notice you have a lot more lift than I do. There just doesn't seem to be enough room for the pitman arm to go straight back and clear the frame rail and the leaf spring. I'm tempted to just put a box on the outside of the frame rail..
Old Mar 10, 2008 | 11:10 AM
P3aflyer's Avatar
P3aflyer
I will lose about 2inchs of travel if I do the crossover, 4 1/2 inch bumpstop required? With that said if I went with the standard drag link, then when the springs flexed the bumpsteer and poor steering control associated with the springs flexing would be enough for me to say ok, I'll lose the 2inches and go with the crossover.. ..
thanks again 73 ford,,
regards,
Old Mar 11, 2008 | 02:41 PM
P3aflyer's Avatar
P3aflyer
update on crossover,
I ordered my kit and will go ahead and install the NWFW arm and drag link.. cost is about 300 bucks but it will be worth it!!
When you consider $200 for and drop draglink, $100 drop pitman and the wear and tear on it and poor steering control of the conventional steering??
The $300 is not a bad option.. By the way the guys at NWFW are great.. I highly recommend this setup for anyone considering a crossover steering setup.. They customize the package to your needs. Not too bad..
My thanks have to go out to 73 Ford guy for paving the way..
Old Mar 11, 2008 | 06:14 PM
73 ford guy
No problem bud...hey just one thing though did they have the stuff in stock?? I thought I would have everything in a week or two from order and it took a couple months by the time it arrived. North West Fab is only about an hour and a half drive from my house!! They were slow but they have some cool stuff no one else carries. My next upgrade is going to the high steer and upgrading stub axles to dana 70 35 spline that they carry.
Old Mar 15, 2008 | 09:59 PM
P3aflyer's Avatar
P3aflyer
well, Matt said that the arm and ends would ship out the next day? He said it would be here by Friday? Well, it din't make it. I will give you an update when it gets here...?????
How much spring travel do you have? It looks like you might not have that much by looking at the your pics?
I will lose some, but over all I should get about five inches with a four inch lift.
Old Mar 15, 2008 | 11:35 PM
73 ford guy
It flexes about the same as this
