Turning up the IP
Old Mar 9, 2008 | 07:32 PM
94F250TD's Avatar
94F250TD
Turning up the IP
hey guys just wanted to no if anyone can help me turn up my ip i've had it turned up when i bought it but i think she could use more i have hardly any black smoke coming out only when i start off a little poof comes out when i stand on it no smoke what so ever i would also like to turn up the boost to about 10 psi i have a bost gauge and an egt gauge so i can monitor my progress i would just like some detailed intructions on how to do so before i tear into to it any advice is good advice!!!
Thanks Guys
Old Mar 9, 2008 | 07:51 PM
F250FarmBoy's Avatar
F250FarmBoy
http://www.members.shaw.ca/k2pilot/
click on the "fuel injection pump adjustment article" link
Bunch of good stuff
Old Mar 10, 2008 | 07:53 PM
94F250TD's Avatar
94F250TD
thanks man i appreciate it!!!
Old Mar 10, 2008 | 08:35 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Are you running the stock Ford turbo downpipe?
Are you running the stock Ford muffler?
If you are you may not be able to get much more boost out of the turbo.
The stock stuff was way to restrictive.
How is the snow?
I used to ski at Loveland and Keystone several times a week.
Yeah, I know that was a dumb question, we are talking Colorado snow.
Old Mar 11, 2008 | 08:22 PM
94F250TD's Avatar
94F250TD
no i have the ats downpipe to a full 4" with no muffler and the snow is good this year alo of it thats for sure!!!
Old Mar 11, 2008 | 08:25 PM
94F250TD's Avatar
94F250TD
and how do i go about turning up the boost? extending the rod out on my wastegate?
Old Mar 11, 2008 | 11:11 PM
Dave Sponaugle
Shorter is increase.
Be careful as you do this.
The rod that goes into the waste gate actuator must not be allowed to turn.
If it does, the diaphram will be torn.
Also the rod is staked on a lot of turbos.
Loosen the lock nut,
Then remove the E clip on the wastegate arm.
Now turn it so you make the rod longer about 1 full turn.
Apply a bit of your favorite penetrant/lubricant and then tru to go shorter.
If it tries to stop at the original position, don't try to hard to turn it farther or you may twist the rod off.
Instead remove the end and run a tap down inside the female end to clean the threads up.
After that is done, try again.
Mine gained 1 PSI for about every two turns.
Keep it under 15 PSI, and watch your pyrometer very closely for a while.
You are high enough that you may have EGT heat problems just from the thin air.
Old Mar 12, 2008 | 09:44 PM
94F250TD's Avatar
94F250TD
thanks dave i'm only shooting for maybe 10 or 11 depends on what my egt's are doing so shorter is more boost? i will only go as far as I can with out applying to much force! and is it any different to turn up my IP on my 947.3L idi as it on the older 6.9 as above posted by farmboy?
Old Mar 13, 2008 | 04:06 PM
Learath's Avatar
Learath
on turning up pumps. i always hear you guys talkign about blowing black smoke under load. my truck has a light blue smoke when i start it up but once it warms up i dont get any kind of smoke coming out no matter what i do. is the pump turned down to much?
Old Mar 13, 2008 | 08:54 PM
Hellonwheels's Avatar
Hellonwheels
As far as i know my ip has never been turned up and i have a steady stream of black smoke pouring out under full throttle. Almost makes me want to cry when i see that cause diesel fuel is regualarly 3.75 a gallon around here.
Old Mar 13, 2008 | 09:15 PM
rmalottwtes30's Avatar
rmalottwtes30
LEARATH- Blue smoke usually means its burning oil, that or dirty injectors.
Hellonwheels- Usually diesels under any type of load will blow a bit of black smoke whether the pump is turned up or not.
Old Mar 13, 2008 | 10:03 PM
Learath's Avatar
Learath
yea i know its burnign some oil, not after it warms up a bit. or at least its hot enough to burn it better. the main drip on it if from either the oil pan gasket or the rear main seal. and im still kicking myself for not changing that when i had the tranny out.
