Offroad & 4x4
multi mount winch
Old Mar 9, 2008 | 06:58 PM
78 Ranger's Avatar
78 Ranger
multi mount winch
i just bought a 9000 pound winch and i want to be able to hook it up on the front and back. i need some ideas on the best way to anchor the winch on the front so it can be easily disconnected and attached on the back. i know that i will need to install quick disconnects for the electrical
Old Mar 9, 2008 | 07:48 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
easiest and best idea is to use/build a hitch mount.....
Old Mar 9, 2008 | 07:57 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
x2 on the hitch mounted winch, i believe there was a bumper build thread that had a hitch in the front bumper as well for the same reason, search for it, its not very old really.
Old Mar 9, 2008 | 09:20 PM
MBBFord's Avatar
MBBFord
That's what I'd like to do also.
Putting a hitch set up in the front and the rear is the way to go.
They make something that can hold up to a 9K lb winch for this exact reason, but I'm wanting at least a 12K lb winch and I'll use a ****** block as much as possible, so I'll want to build something custom/strong as hell, only problem is it will be pretty heavy....
It's still in the planning stages.
Old Mar 9, 2008 | 09:25 PM
Truckin4life
matt just an idea in my head. have the winch mounted to a plate of steel, then have the steel slide into a slot on either front or rear and have 2 pins to lock it in place, winch would slide in from back so pins arent holding all the weight. just an idea, could draw something up if you want more detail. also just came off top of the head.
Old Mar 9, 2008 | 09:41 PM
MBBFord's Avatar
MBBFord
IF I had $2,000 to waste, I could get something like this: http://www.winchesplus.com/winch-hitchwinch.html
But at 190 lbs with steel cable, that'd be one hell of a thing to haul from the front to the back.
Old Mar 9, 2008 | 09:43 PM
Truckin4life
that could be real usefull. 2k, hmmm...
Old Mar 9, 2008 | 09:44 PM
STGFordCrazy04's Avatar
STGFordCrazy04
that thing has a saginaw steering pump on the side! Bad assness!
Old Mar 9, 2008 | 09:48 PM
MBBFord's Avatar
MBBFord
Very bad ****, but $2K!!!!!!!!!!
Something like this just doesn't seem strong enough.
http://www.etrailer.com/pc-OR~5440.htm
Old Mar 9, 2008 | 10:26 PM
chrono4's Avatar
chrono4
I'd just get a piece of 2x2 .25 wall tubing, and a length of 8 inch wide c channel. Notch the c channel to fit the tube (for more mating surface) and maybe a brace to help with side pulls. It may weight 50 pounds without the winch, but it's not going anywhere.
Old Mar 9, 2008 | 10:42 PM
MBBFord's Avatar
MBBFord
You guys have any idea how the best way to mount a hitch(reciever) to my front bumper(pipe bumper)?
Or should I just make some kind of permanat cradle for a front winch?
Old Mar 9, 2008 | 10:46 PM
chrono4's Avatar
chrono4
what about just torching a square hole in the tube and sliding in a receiver and welding it in? Just one of the 20 dollar ones at tsc.
Old Mar 9, 2008 | 10:58 PM
MBBFord's Avatar
MBBFord
I thought about something like that, but I'm not sure if the PO filled it with concrete, that'd be about the only way to do it though huh..?
As for the rear? Same thing... torch a hole throught the bumper, or mount and brace it under it, or I don't know.?
Old Mar 9, 2008 | 11:10 PM
chrono4's Avatar
chrono4
I would do it through as opposed to under, just one less thing to get hung up on. When my bronco had the hitch on it, I was always getting it hung up on stuff, especially since it was one of the types that you can't remove the ball mount from. Night and day difference once I changed my rear bumper and ripped the hitch off.
Old Mar 10, 2008 | 10:54 PM
rebocardo's Avatar
rebocardo
On the 79 Bronco I would just put a piece of 6x6 x 1/4" tube over the frame rail (basically cut off the top section where it goes over the frame and reweld a piece of plate over the cut off section to bolt through). It will give enough surface area beyond the grill to mount a winch.
