Problem with Water in Fuel
Old Mar 9, 2008 | 10:50 AM
wade456's Avatar
wade456
Hi All. Been a long time and I need your help. I have a 03 F250 with a 6.0 and love it. My Problem seems to be with bad fuel or so I believe. About a 3 Weeks ago my Water in the Fuel light came on.I changed the 2 fuel filter's and drained the water. Now again the light came on. I will drain the water again but there seems to be a problem somewhere. Is there an Additive I can use that will help. Thanks Wade
Old Mar 9, 2008 | 11:00 AM
mrxlh's Avatar
mrxlh
Wade, it might not be a problem with your fuel quality at all. The 03 models had issues with the WIF sensors and the HFCM fuel heaters which was discontinued for MY 04. If its under warranty, definately bring it to the dealer for repair. They will give you the new updated cover without the heater and the better sensor. I had the same issues on my 03 until they installed the updated cover on mine.
Old Mar 9, 2008 | 09:57 PM
wade456's Avatar
wade456
Thanks for your Info Ryan. Stupid Question on my part ???? What do you mean when you update cover??? Is that the Computer. Yes this Truck is still under warranty until this September. If I take it to the dealer what should I tell them ?? Thanks for your Reply and your Help Wade
Old Mar 9, 2008 | 10:08 PM
bismic's Avatar
bismic
Updated HFCM (Horizontal Fuel Conditioning Module) cover. It is the frame rail mounted filter cover.
https://www.ford-trucks.com/tsb/full...php?tsb=06-6-5
http://dan.prxy.org/Truck/Owners_manual/Service_Points/HFCM/HFCM.html
Old Mar 10, 2008 | 06:49 AM
wade456's Avatar
wade456
Thanks fo your advice. I will see what the Dealership will say and do about this problem. Thanks again Wade
Old Mar 10, 2008 | 07:33 PM
wade456's Avatar
wade456
Just wanted to thank both mrxlh and bismic for your help. I took my Truck to the Dealership Today and you were right. They Replaced a Bad Water Separator Manifold/ Fuel Conditioning Module and a Wire Asy. for the fuel pump. Thanks Again for your help. Wade
Old Mar 10, 2008 | 07:51 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Ain't FTE great?
Old Mar 10, 2008 | 07:52 PM
msgtg's Avatar
msgtg
Wade,
One way to say thanks to these guys that really help is to give the positive rep points.
Look at each post. Notice the little white scales after the post number. When you click on it a Reputation Points window opens. Say positive things...it's our way of thanking the guys.
Joe
Old Mar 10, 2008 | 08:18 PM
wade456's Avatar
wade456
TY MSgtG Had no Idea until your last reply. Have Thanked all and you. Thanks again Wade
