Sponsored by: Real Truck
Sea Foam
Old Mar 9, 2008 | 10:39 AM
FordSDF250's Avatar
FordSDF250
Sea Foam
Have any of you guys heard of sea foam moter treatment and use it in your trucks. I have a 2001 f250 with a 7.3 and i was woundering if its ok to put it through my diesel engine.
Old Mar 9, 2008 | 10:52 AM
redford's Avatar
redford
FTE Leadership Emeritus
I use Sea Foam on my gas engines, it does a great job of cleaning.
Can't speak to how well it will work on a Power Stroke.
Old Mar 9, 2008 | 02:23 PM
cartmanea's Avatar
cartmanea
I've also used it on gas engines, but I wouldn't go near a diesel with it.
Old Dec 14, 2008 | 01:25 PM
5.4L to Freedom's Avatar
5.4L to Freedom
My roomate is a huge diesel guy... 04 cummins and a 95 powerstroke. He has never put it in his cummins but adds a pint of it to his oil in the 7.3 and uses it as a top engine cleaner and swears by it. He dont put it in the fuel tho b/c he's got some other additive that is more cost effective
Old Dec 14, 2008 | 01:37 PM
nitrogen's Avatar
nitrogen
you certainly can not pour it in the intake like on a gasser, very bad for engine. the reason it works on gas engines is that the fuel is sprayed on the back of intake valves and it helps soften carbon depoisits so they flake off. on diesels the only thing in the intake is air so valves don't really carbon up anyways, the fuel injects directly into the cylinder. no pour into gas tank additive will do anything for exaust valve buildup, because its already burnt by the time it get to the exaust. as far as the exaust buildup on a diesel if you just work it hard enough it will burn itself clean kind of like a controlled burn in a chimney fire
Old Dec 14, 2008 | 02:33 PM
aphotic26's Avatar
aphotic26
I was watching some official sea foam videos they said its allowed on diesel applications
http://video.google.com/videoplay?do...90865726229173
go to about 4:00 min they talk about it then
Old Dec 14, 2008 | 03:01 PM
eodmule's Avatar
eodmule
About every third fuel filter change I fill the bowl up with it to do a great job of cleaning up the injectors.
Haven't had a problem yet.
Old Dec 14, 2008 | 06:13 PM
5.4L to Freedom
I did mispeak myslef in the above post that you responded to. He puts it in the oil, not as a top engine cleaner. He uses power service with the slick diesel in the tank for lubrication and maybe water separater. He seems to like it, just thought I should contribute
Old Dec 14, 2008 | 07:07 PM
senix's Avatar
senix
kinda reminds me of STP...would never use that!
Old Dec 14, 2008 | 07:08 PM
patrickke's Avatar
patrickke
i had a bad experience with stp...needless to say my truck will never support richard petty again
Old Dec 14, 2008 | 08:46 PM
azfordf100man's Avatar
azfordf100man
I wouldn't do it. Seafoam says it can go in the motor, but it will thin out the oil. I'd only do it before an oil change maybe.
The only motor cleaner I use is Auto RX, it takes time, but works better than anything i've tried.
Auto-Rx Engine Cleaner
Old Dec 15, 2008 | 08:00 AM
nitrogen's Avatar
nitrogen
as said by others the problem with adding stuff to the oil on the 6.0 is the fact that about 3 quarts of oil stay in the hpop and don't get changed. if you are ok with that, cool. alot of people are not so cool tho
Old Dec 15, 2008 | 11:13 AM
cartmanea's Avatar
cartmanea
more like 1 quart
Old Dec 16, 2008 | 07:48 AM
counciller's Avatar
counciller
And doesnt that oil get circulated on a continuous basis?
Old Dec 16, 2008 | 09:37 AM
dkf's Avatar
dkf
I don't have faith in seafoam. I've tried it in the headstock of one of my lathes to see if it would clean off the crud film on the inside. I added a full can of seafoam to 4.5 quarts of 20w-50 ran it for 5 hours and took the cover off. Seafoam did nothing. Apples to Oranges comparision but.... I have a problem putting a solvent in my engine oil especially a harsh solvent like seafoam. I add fuel injector cleaner once every year and don't baby the truck, no problems.
