help
Old Mar 9, 2008 | 09:41 AM
s_steeves's Avatar
s_steeves
help
can someone help me i pulled out my distributrer and the oil pump driveshaft fell in the motor and i cant get it out with a magnet. its a 91 302 ho i can still see it in there; am i going to have to take off the oil pan?
Old Mar 9, 2008 | 10:18 AM
GLR's Avatar
GLR
Did it actually fall in the motor or stay in the oil pump? Usually there is a clip to keep the pump driveshaft from coming out when you remove the dist. If you can see it, it's probably where it belongs. Try a 1/4" drive socket and ext on the O/P shaft to see if it will still turn ok. You are probably OK.
Old Mar 9, 2008 | 12:04 PM
s_steeves's Avatar
s_steeves
oil pump help
it looks like it is on its side
Old Mar 9, 2008 | 02:55 PM
GLR's Avatar
GLR
Time to try a small magnet...
Old Mar 9, 2008 | 04:19 PM
Franklin2's Avatar
Franklin2
I have heard of people just leaving the old one in there and buying a new one and installing it. You might want to talk to someone who works on Fords all the time, and if you find someone, I am wondering how many they say they have left in the pan.
Old Mar 9, 2008 | 04:27 PM
stila_r8dr's Avatar
stila_r8dr
That only works if it went all the way down into the pan.
Try one of them grabber things.
Old Mar 9, 2008 | 08:19 PM
blue beast's Avatar
blue beast
Get a neodyium magnet and superglue and wrap some safety wire around it on to
a rod and use that to grab it. Or you could take apart a microwave and break the
magnet that is on the magnetron and use that they are super strong magnets and
either one needs to be attached firmly to the rod or else you will get that magnet
stuck inside the motor too since they are so strong!!
Old Mar 10, 2008 | 04:56 PM
s_steeves's Avatar
s_steeves
i got it out but i had to take the oil pan off it was bent how would that happen?
Old Mar 11, 2008 | 08:16 PM
magusjinx's Avatar
magusjinx
Why did you pull the distributor in the first place?
