After replacing Starter, Battery, Solinoid, and all the wires i could think of i've finally come to the conclusion that my flywheel wont turn. Is there anyway to crank that SOB without the starter i tried pulling on a belt but it seems frooze up....what do i do??? Anyhelp would be greatly appreciated!!! I need to get this truck goin' b4 the snow hits!!!
>I don't know what your working on, but if you can get into
>it, put a socket on the crankshaft dampner bolt and try and
>turn the motor over.
Ok got the fkywheel turning via socket wrench ,but seems like my starter isnt turning it. Could it be i have a weak starter? I took it in to get it checked and they said it was fine but im having doubts. I took off the flywheel plate and can see the starter trying to turn the flywheel but it just cant do it. What now?!!?1?
