How much ATF
Old Mar 8, 2008 | 11:54 PM
George D.'s Avatar
George D.
How much ATF
I'm planing on servicing my trans and pulling the accumulator hosing to do som modification how much ATF will I need?
Old Mar 9, 2008 | 11:06 AM
PLC7.3's Avatar
PLC7.3
The 4x2 uses 15.7 quarts/14.8 litres
The 4X4 uses 16.2 quarts/ 15.3 litres
If you can drain the Torque convertor via the small plug (if yours has it) and the rad cooler and aux cooler then get 16 quarts........
Remember to get the correct filter by application 4x4 or 2x4...... ensure the neck seal comes out with the old filter, if not gently remove it "USE NO STEEL DENTAL PICKs" it may scratch the bore.
Old Mar 9, 2008 | 11:11 AM
George D.'s Avatar
George D.
Thanks Pete.
