1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
LED Lighting
Old 03-08-2008, 11:12 PM
mdntblu's Avatar
mdntblu
mdntblu is offline
LED Lighting
Has anyone replaced their interior lights to LED (White)? I did this on my VW Beetle and it looks really cool and actually brighter. I was wondering what light bulbs people used if they have? I know it takes the wedge bulbs but which ones work best?
Old 03-09-2008, 07:20 AM
Johnny Langton's Avatar
Johnny Langton
Johnny Langton is offline
I had melted lamp msockets on the Navigaor,and had to hardwire in new LED's just to get front "map" lights again. I purchased the LED PC board lamps from www.superbriteleds.com.
I got the T10-PCBW36.
I alos swapped all of the rear OH lighting out with their "festoon" lamp replacements so all the interior lighting matches.
JL
Old 03-10-2008, 07:40 PM
AF Mezkin's Avatar
AF Mezkin
AF Mezkin is offline
Can you post some pics Johnny?
Old 12-21-2008, 10:19 PM
dan_s_johnson's Avatar
dan_s_johnson
dan_s_johnson is offline
Will LEDs from these links fit an 03 expy?
http://www.mouser.com/catalog/636/2345.pdf
JKL Components Corporation
Part No. LE-0503-03W
Old 12-24-2008, 03:17 PM
mdntblu's Avatar
mdntblu
mdntblu is offline
Well what I realized is the in the Expedition the bulbs actually face the up instead of down and there is a reflector at the top. So what happens when you put an LED bulb in is the light just goes up through the little hole in the reflector and doesn't really do anything. I was going to try and put the bulb in backwards but it wouldn't fit. So there needs to be some sort of retrofit kit we have to use to get the 4 lights to work right. I haven't opened up the back one by the tailgate so I don't know how it looks. Any ideas?
Old 12-31-2008, 07:10 PM
Gerdva's Avatar
Gerdva
Gerdva is offline
I did it on mine (2000 EB) I was concerned about the heat of the bulb burning the transparent plastic cover, I could not find anything similar to those of the links posted (mouser and superbrightleds) so I went with some very bright 10 milimeter white leds I could find localy ( I'm in the middle of Mexico). It was a lot of work and finally after a few days I pulled everything and went back to the original lights because it looked really SPOOKY, like a cementery under moonlight. So, no thanks. Although they gave good light but again, could'nt get used to this spooky light.
Old 04-06-2013, 10:46 AM
mdntblu's Avatar
mdntblu
mdntblu is offline
I still haven't replaced mine, any new updates on this in the year 2013??
Old 04-07-2013, 08:19 PM
TXtinct's Avatar
TXtinct
TXtinct is offline
You'll shoot your eye out
I just did mine earlier today. I got a 2010 last weekend, can't believe it took me so long to swap 'em out. I did my Excursion almost two years ago and love it. Here are a few pics... What year is your truck?
Here's a before:
After:
Before:
After:
Before:
After:
Reverse:
License plate:
Map lights:
Glove box:
Old 04-07-2013, 09:57 PM
dan_s_johnson
Very nice. Pictures are a great help. What leds did you use and what was the total cost?
Old 04-08-2013, 09:30 AM
TXtinct's Avatar
TXtinct
TXtinct is offline
Everybody loves pictures... Some of these are just stock pics I pulled off of google but here goes.
For the front and second row map lights I used these: (4 194 bulbs)
For the cargo area and glove box I used this x 2:
For the reverse lights I used these: (921)
For the license plate I used 2 of these flat 194 bulbs:
As for the cost, I don't have my price list with me and I haven't bought any in some time so I'm going to guesstimate the price around $30-$35. I still need to do the puddle lights but that was more involved and I ran out of time. I will post up some pics when I get that done.
Old 04-08-2013, 07:59 PM
TXtinct's Avatar
TXtinct
TXtinct is offline
I forgot to post a pic of the vanity mirrors so here you go:
Before:
One light swapped:
After:
Old 04-08-2013, 08:02 PM
TXtinct's Avatar
TXtinct
TXtinct is offline
BTW if anyone needs or wants any help putting all this together shoot me a message and I'll try to help you out. I have most of these bulbs in bulk.
Old 04-09-2013, 12:04 AM
5.4T's Avatar
5.4T
5.4T is offline
How did you install these? last time I try to remove the front overhead console light cover off I couldn't any tips? Should be the same as your Excursion
Old 04-09-2013, 09:12 AM
TXtinct's Avatar
TXtinct
TXtinct is offline
The light cover simply pops off, you just need to use a small flat head screwdriver to pry it a little. You should see a few little grooves along the edge where you can stick the screw driver in. To connect the bulbs they come with different types of bases so you can choose whichever you need. Here's a google pic of just an example of the type of bases that you can pick from.
jaybob1807
2009 - 2014 F150
06-24-2017 12:34 PM
GORDEN1234
2015 - 2020 F150
03-06-2017 08:13 PM
skippyf15
1999 to 2016 Super Duty
15
10-02-2016 08:39 PM
Larietpsd
2015 - 2020 F150
04-14-2016 10:47 PM
ALAN_50501
Aftermarket Products
09-27-2015 09:13 PM
Quick Reply: LED Lighting
