General Automotive Discussion
89 suburban specs
Old Mar 8, 2008 | 07:02 PM
Iversen-fords's Avatar
Iversen-fords
89 suburban specs
This is for my cousins 89 suburban. He blew out the rear end and and we couldnt figure the gear ratio at all. We couldnt find the manual also. We have a couple of older chevy from the late 70s and and 80s. I was wonderin will a 70s rear end work a 89. also what were the gear ratios offered in 89 for a 4x4 suburban. I am unable to look up most website with my school labtop because they have so many programs that block out everything. Thanks
Old Mar 8, 2008 | 08:16 PM
mrshorty's Avatar
mrshorty
If you're certain he's running the factory ratio, look in the glove box for the RPO code list. I think it should be a Gxx code, then look up those RPO codes in one of several RPO code lists on the internet.
Old Mar 8, 2008 | 09:51 PM
Krochus's Avatar
Krochus
the number of ring gear teeth and pinion teeth are stamped on the gear set. It should read something like 14:41
14 is the number of teeth on the pinion gear
41 represents the number of ring gear teeth
divide 14 into 41 and VIOLA! you get the gear ratio, in this example 2.92
Old Mar 8, 2008 | 10:03 PM
ranger1999 Bob's Avatar
ranger1999 Bob
well you could sign up and ask in chevytalk or 67-72chevytrucks com
Old Mar 9, 2008 | 11:18 AM
Iversen-fords
Thanks for the info, well i guess i dont any specs now. We took a close look and he only blew out the spider gears. were just going to weld them up sometime soon.
Old Mar 9, 2008 | 01:12 PM
vman's Avatar
vman
Check the tag on the front axle.It should give you the # of the ring and pinion.Most of those had 3.08's in them.Them options were 3.73 or 4.11. The rears wre weaklinks.If you can find a 12 bolt housing out of an 80 or earlier,I would definitely recommend it.
rockhounds4x4
Nov 14, 2017 06:22 PM
axelgawn
Georgia Chapter
Mar 5, 2016 06:20 AM
bronco6767
1997 - 2003 F150
Jun 6, 2015 11:30 PM
DSN46
Oct 28, 2013 11:48 AM
AJParry89
Aug 23, 2012 02:56 PM
