Funny thing
Old Mar 8, 2008 | 04:27 PM
mollikate's Avatar
mollikate
Funny thing
happened to me at the lake this morning.Got in my truck to leave and p/wdos did not work, or my instrument cluster. Checked all fuses and relays and could not find anything wrong. On the way home someone pushed the door lock button and everything went back to working. Problem solved right,wrong. Let go of the button and every thing dies again. Please help me I am very confused.
Old Mar 8, 2008 | 05:11 PM
PaysonPSD's Avatar
PaysonPSD
When you say you checked the relays what do you mean? My down and dirty way is to exchange 2 relays of the same type and see if the problem changes. Another thing I would do is have someone push and release on the door lock button while I was trying to hear or feel a relay operating. This may help lead to a starting point for diagnosing this problem. But after saying all this let me tell you I am also confused.
Old Mar 9, 2008 | 08:27 AM
mollikate's Avatar
mollikate
My relay technique is the same as yours. I also discovered that with ign. off and key out the flasher relay clicks and turns radio light and cargo light on and off. With key in ign. and turned off my radio plays.I tried new rlays at all positions with no change
Old Mar 9, 2008 | 08:32 AM
HKusp's Avatar
HKusp
Molli, what year is your truck? It wouldn't happen to be a 2002 would it?
Old Mar 9, 2008 | 04:14 PM
mollikate's Avatar
mollikate
I have an early 99'. I read some search post with similar problems but not all of my problems that lead to steering column wiring problems. I quess that is where I will continue my search.
thanks guys,
Michael
Old Mar 9, 2008 | 04:38 PM
F350-6's Avatar
F350-6
Some early 99's had problems with the windshield leaking and getting the back of the fuse panel wet. Did you have any rain recently?
Old Mar 9, 2008 | 04:48 PM
superpony18's Avatar
superpony18
I have an '01 that the windshield leeked and took out the tranny twice before Ford figured it out. Couldn't see the leek.
Old Mar 10, 2008 | 07:55 AM
mollikate's Avatar
mollikate
I found my problem.The kick panel on the drivers side has a ground behind it and apparently I put my foot on it one too many times and broke it.Thanks Guys,
Miichael
Old Mar 10, 2008 | 08:04 AM
HKusp's Avatar
HKusp
Good to know Molli, good to hear that you got it fixed.
Old Mar 10, 2008 | 09:30 AM
PaysonPSD's Avatar
PaysonPSD
Glad you got the problem fixed. Another fixit to store away for later use. Its gonna happen to somebody again. I just hope they know about FTE.
