4" mbrp off road
Old Mar 8, 2008 | 03:16 PM
Ftree50's Avatar
Ftree50
4" mbrp off road
if you delete the cat with this system, would it void your waranty. also i live in virginia so theres so emison tests
Old Mar 8, 2008 | 03:52 PM
mnmwhit's Avatar
mnmwhit
No.
your warrenty can only be voided if you find out you need a repair that a MOD you installed caused the malfuction.
Old Mar 8, 2008 | 11:43 PM
07psdrookie's Avatar
07psdrookie
Or the whole emissions tampering federal offense thing. Read your manual. A lot of dealers won't touch your truck until you put the cat back on.
Old Mar 9, 2008 | 06:09 AM
HeavyAssault's Avatar
HeavyAssault
Using a MBRP turbo back kit with the MBRP cat delete pipe will allow you to swap the cat back in for inspections. The turbo back kit will use a DP with a two bolt flange that will allow the cat to mate to the new DP. Using the MBRP cat delete pipe, you can drop the cat and have a straight piped exhaust. I'm in Central VA, if you want to see my set up PM me and we can meet up.
