timing chain
Old Mar 8, 2008 | 11:52 AM
chadrsmith's Avatar
chadrsmith
timing chain
Hi, I've posted a little before about my truck early this spring I'm going to put on a edelbrock 2171 holley 650 dp headers ect. I was wondering is it really worth it to get a double roller timing chain set straight up. does 4 deg. really make a huge difference? my truck has 120,000 miles but runs good,good comp,and oil press. next winter the engine is coming out for a total rebuild. would it be worth while to do the timing chain now and if so should I replace the water pump for good measure while I have it apart. thank you
Old Mar 8, 2008 | 12:02 PM
chadrsmith's Avatar
chadrsmith
I forgot to put that the engine is a 400
Old Mar 8, 2008 | 12:31 PM
hollenjoe's Avatar
hollenjoe
well yeah you will gain some more torque, also, why not change you camshaft while you´re at it, that will realy wake your engine up...
