240/300 distributer set up help?
Old Mar 8, 2008 | 10:15 AM
kssouth's Avatar
kssouth
i am installing a 1985 300 i6 into my 1965 f250 .the 300 has a map sensor and modern coil.my problem is that i don't know how to wire the sensors into the old system .or would it be better to get rid of the map and coil and install a older vaccum advance distributer and coil . and also is the 240 distributer shaft the same as the 300 distributer shaft .. because i pulled a 240 i6 out of the truck and could possible use the distributer set up off that old motor...any help would be greatly appriciated
