Coolant filter
Old Mar 8, 2008 | 07:11 AM
Jaaaaaaackman's Avatar
Jaaaaaaackman
Coolant filter
For those with the Coolant filter were did you get it and how often do you need to test the coolant with the filter? And how long between filter changes do you go?
Old Mar 8, 2008 | 07:53 AM
MADVAN's Avatar
MADVAN
http://www.intellidog.com/dieselmann/catalog.htm
OR
http://www.dieselsite.com/
Bill
Old Mar 8, 2008 | 08:56 AM
Jaaaaaaackman
Thanks Madvan, I think a coolant filter will be my first mod.....
Old Mar 8, 2008 | 09:03 AM
93f1505.0L's Avatar
93f1505.0L
What is the point in runnign one? Im guessing longer engine life or something like that. Ive seen a few people running them and always wondered why.
Thanks
John
Old Mar 8, 2008 | 09:04 AM
Jaaaaaaackman
Keeps the coolant clean and also I am hoping to also maintain my sca's with less maintance.
Old Mar 8, 2008 | 09:28 AM
MADVAN's Avatar
MADVAN
I dont recommend the loaded filter.
I have tryied on the PSD and it has allways made the SCA to high.
Bill
Old Mar 8, 2008 | 10:26 AM
Jaaaaaaackman
Madvan are ya still doing sca in a bottle with test strips? If the sca is too high what is the bad?
Old Mar 8, 2008 | 10:29 AM
MADVAN's Avatar
MADVAN
Yes still test/strips. You could upgrade to ELC.
To high of SCA is hard on pumps.
Bill
Old Mar 8, 2008 | 10:35 AM
Jaaaaaaackman
ELC thats a new one to me Ill have to check that out....... was hoping to forgo the test strips.
Old Mar 8, 2008 | 11:15 AM
kawa's Avatar
kawa
I purchased mine from Dieselmann's and do not run a charged filter. One of the main purposes of the filter is to remove the grit, scale and other inpurities that is in the coolant. This stuff causes wear and tear on seals, hoses and aluminum parts in the engine.
The filters last a very long time unless you have a real gunky system. Just feel the filter and if it is not hot it's time to change.
You should be maintaining your SCA level if you have a filter or not. Once you get your SCA level set it should be good for a year ar so but you should d occasional test just like you would a pool or jacuzzy but not that often.
The filter is tied into the heater hoses. The hose that come off of the pass head area is a pressure line and the hose that attaches to the heater hose on the top of the water pump is the return line. The kit (if you get a kit)
supplies you with "T's".
You can see where I installed mine in the photo's in the thread entitled:
"Shroud Mod"
Rog
Old Mar 8, 2008 | 11:50 AM
Jaaaaaaackman
Thanks Kawa , Ill check your pics.....
Old Mar 8, 2008 | 12:03 PM
MADVAN's Avatar
MADVAN
On another note.
Install ground straps on rad and heater core.
It will stop the electrolysis issues.
Bill
Old Mar 8, 2008 | 12:08 PM
Jaaaaaaackman
Originally Posted by MADVAN
On another note.
Bill
Cool I like that kinda info,,,,,,,,, will do it makes sense I think
