Muffler delete= check engine codes and poor performance?
Old Mar 7, 2008 | 11:30 PM
redfire42's Avatar
redfire42
Ask him how much BP a 5" straight pipe would make . Ask him what codes I should see, a " thats a big a$$ exhaust" code or "making to much noise" code
Old Mar 8, 2008 | 12:06 AM
UP_There's Avatar
UP_There
He is using the theory of backpressure for a GAS engine. Never ever heard of any codes from straight exhaust. I've had both on my truck, and no codes, I too get that "whoosh" of cold air from the passenger rear window now that I have 4" and straight piped
Old Mar 8, 2008 | 12:32 AM
That_Guy's Avatar
That_Guy
I think that cold air from the pass. side comes standard with all new turbo back exausts now...
Old Mar 8, 2008 | 12:51 AM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by ron01sd
how about a double bullsh.it burger with a side of turd totts
LMAO Thanks Ron, I needed a good laugh before I head off to bed. It will give me a good start on tomorrow.
Old Mar 8, 2008 | 01:21 AM
RogueSpear2023's Avatar
RogueSpear2023
The guy doesn't know what he is talking about, back pressure is really only needed for the engine, and the back pressure in a PSD is created by the turbo. Cut out the muffler it will run great, plus faster spool up, so more peformance not less, and I don't know why it would throw a code, besides EBPV creates the back pressure to warm up the engine faster, it should matter what is behind it.
Old Mar 8, 2008 | 07:55 AM
TXCC1952's Avatar
TXCC1952
A buddy put my 4" , turbo back straight pipe in last weekend, and a big box intake, Sounds great, the rushing air in the morning, is from the waste gate shutting, until it warms up, he says.. He used to be a Ford diesel mechanic, .02 worth
Now I, have to replace my front wheel bearings. He said use Ford stuff, he can get a deal, what do ya'll think?
Old Mar 8, 2008 | 08:00 AM
sideshow's Avatar
sideshow
better question, have you been running that DP tuner with a stock exhaust until now? what kinda EGT's you been seeing?
Old Mar 8, 2008 | 08:11 AM
1996pwrstrk's Avatar
1996pwrstrk
Thats not the waste gate closing it's the EBPV closing to help it warm up.
Old Mar 8, 2008 | 09:34 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
If you get the 6637, don't show that guy. He will tell you to take it off because you are not getting enough IBV ( INTAKE BACK VACUUM) so your turbo wheel don't fly off.
Old Mar 8, 2008 | 09:43 AM
pf350's Avatar
pf350
no muffler, my computer doesn't throw codes but my neighbors throw other things.
Old Mar 8, 2008 | 01:22 PM
stormyrider's Avatar
stormyrider
If you have a turbo on the engine, it will supply the back pressure.
Old Mar 8, 2008 | 01:25 PM
HKusp's Avatar
HKusp
Yeah, I have been getting up to 900 degrees on it in 80E empty and I have seen 1200+ loaded with the horse trailer passing someone in 60 tow. I do have the 6637.
He used to be the head diesel mechanic at a very reputable Ford dealer outside of Baltimore, but he has to be crazy on this one.
I'm going to take it somewhere else.
Old Mar 8, 2008 | 01:31 PM
  #28
DCSpecial's Avatar
DCSpecial
I've ran a 4" with a muffler, 5" no muffler, and now 4" duals with no muffler.
Never any codes.......just gets loud with out a muffler, but I like it. The 4" duals is the loudest setup I've run.
Old Mar 8, 2008 | 01:39 PM
  #29
DR JOE's Avatar
DR JOE
Originally Posted by cookie88
Uh....no. The turbo creates all the backpressure the engine needs, and the EBPV doesn't need backpressure, it makes it.
I would have to agree with Cookie, your friend is thinking of a Gasser and not a TURBO charged diesel.
On a gas motor this would be true, as anyone that has had the bright idea to remove the muffler or run open headers will tell ya.
Ya I opened the headers and I have no low end now... It's weird... And I don't know what happened???
I have never owned a non-turbo diesel motor vehicle, so I do not know the effects that it would have to open the exhaust on one.
Doing mine next week...
Doc.
Old Jan 23, 2009 | 10:06 PM
  #30
gmm's Avatar
gmm
I had an old chevy 350 and had exh. cutouts for racing and had no problems with running open headers (other than the noise and heating up my legs when I got out).
I did have a high duration cam so I didnt have low end anyways, but thats why I ran tall gears.
It was an old 78 1/2 ton pickup that ran mid 11's. I blew the doors off plenty of "hot rod" cars with it, including a built 69 coupe Mustang and a 95 IROC Z28. Both of them by at least a truck length. Maybe I was missing power from only running headers into a 4" 90* piece of pipe about 10 " long, but I didnt notice.
As far as a diesel goes, open up the exhaust. The faster you can get the exhaust out, the better it will run.
