Converting to Point-less Ignition
Old Mar 10, 2008 | 06:10 AM
Hakk's Avatar
Hakk
I've put the Pertronix in a few older cars. It works great. I put one on my '65 when I first got it. You'll get more power and/or better gas mileage depending on how far you push the pedal down. Duraspark works ok too (I'm running it on my '70), but I prefer the Pertronix. It's easier to install and there are fewer wires for a cleaner looking engine compartment.
Old Mar 10, 2008 | 09:49 AM
airharley's Avatar
airharley
I'm running a GM HEI style distributor in my truck to replace the old Dur-a-spark II which replaced a Crane XR-700 system that replaced the old point system. So far the only issues I have noticed between all the different systems is external boxes for the Dur-a-spark and XR-700. The each one performed just as well as the other but ultimately I like the GM HEI. I literally has 2 wires running to it; one for the coil power and the other is a tach signal. The XR-700 used a slotted disc under the rotor and IR light to fire the plugs. Dur-a-spark uses a magnet system like the Pertronics, so it should be just as reliable if you set the base plate correctly.
Old Mar 10, 2008 | 07:12 PM
garbz2's Avatar
garbz2
And be sure to carry a spare set of new points just in case the pertronics takes a dump....
Been there and done that Thrice......
Garbz
Old Mar 10, 2008 | 07:54 PM
Hakk's Avatar
Hakk
Garbz
I've run them for years and years (well over 10) and never had a failure. Did you ever figure out why yours failed? Was it a manufacturing problem or a wiring problem?
Old Mar 10, 2008 | 11:56 PM
garbz2's Avatar
garbz2
Early units, and a combination of critters chewing on the wiring allowing an errant ground.
I run a pertronics now with a flame thrower in my crew and have no issues with this one.. but no mice hanging in the heat here so far.
Garbz
Old Mar 15, 2008 | 12:31 PM
FitchBanjos's Avatar
FitchBanjos
Just finished installing the Pertronix Ignitor , Flamethower coil, and Pertronix wires. What a difference! The engine even "sounds" different. I romped on it it at about 30mph and the rear end sqwatted down and I could really feel a HP difference. Acceleration is smoother and, it starts as soon as the key is bumped. It was a very easy installation that took only a few minutes. I highly recommend this upgrade for any FE that is still running points.
Old Mar 15, 2008 | 01:18 PM
matt2491's Avatar
matt2491
Nice. Enjoy it!
Old Mar 15, 2008 | 03:16 PM
matt2491's Avatar
matt2491
Did you just purchase the Pertronix Ignitor I? Or did you also consider the Pertronix II but disregard it for some reason?
Old Mar 15, 2008 | 03:25 PM
FitchBanjos
I used the ignitor 1 because it came in a good package at a great price off of Ebay.
Old Mar 15, 2008 | 03:33 PM
matt2491's Avatar
matt2491
Gotcha! Great prices are always great incentives.
Old Mar 15, 2008 | 05:56 PM
FitchBanjos
Another thing I noticed aftre the upgrade is that my engine doesnt sound as strained at highway speeds like it did before. It is quieter at cruising speed. I found that interesting. I am anxious to check my fuel mileage ; )
Old Mar 15, 2008 | 06:02 PM
matt2491's Avatar
matt2491
Hmm, interesting. What are you running again, a 352?
Old Mar 15, 2008 | 06:04 PM
  #28
FitchBanjos
Yeah, stock 352, auto trans.
Old Mar 15, 2008 | 08:28 PM
  #29
Customcab's Avatar
Customcab
Cliff; what was the total cost with a package deal? And I assume instructions came with it?
Mitch
Old Mar 15, 2008 | 08:38 PM
  #30
FitchBanjos
Mitch, I paid $135.00 shipped for it and yes, all 3 components came with instructions. It couldnt have been any easier to install.
