fuel pump eccentric on 351W
Old Mar 9, 2008 | 10:32 PM
baddad457's Avatar
baddad457
Just remove the four bolts going into the timing cover and maybe two-three of the ones behind these, then loosen the rest to let the pan hang down a bit.Once you get the timing cover back on, pull the pan back up in place along with the pan bolts.
Old Mar 10, 2008 | 02:52 AM
HemiEater's Avatar
HemiEater
if the eccentric moved than it's loose... I would take it apart and remove it or replace it, just don't leave it in there... what happens when the one bolt holding the cam gear on fall out???
stercorarius
Jul 2, 2016 09:52 AM
rcfreed
Jun 26, 2015 01:20 AM
Bronco Billy
Sep 19, 2014 01:09 AM
medino03
May 14, 2012 10:24 AM
davelength
Aug 18, 2009 08:45 PM
