Sponsored by: Auxito
What would happen.........????
Old Mar 7, 2008 | 02:23 PM
dafireman's Avatar
dafireman
What would happen to my '03 5.4 if I filled half my tank with e-85 and the other half with reg. gas??
Old Mar 7, 2008 | 02:40 PM
bowdog's Avatar
bowdog
your mileage would go down!!!
Old Mar 7, 2008 | 03:02 PM
Bobby82490's Avatar
Bobby82490
ummm......you would have a full tank of gas??
Old Mar 7, 2008 | 03:09 PM
dafireman's Avatar
dafireman
Let me re-phrase my question...what would happen to the components of my engine if I mixed half tank e-85 and half regular gas??
Old Mar 7, 2008 | 03:43 PM
Thomas Hutchins's Avatar
Thomas Hutchins
There is a very good reason why Gasohol is limited to a Max of 10 to 15 % EOH, and then you jump to the E85 blend. It is called Phase seperation and it can take place with increasing amounts of EOH or MeOH above the 15%. The EOH or MeOH will collect any water in the tank, ala DryGas, and it will then seperate from the gasoline leaving you with nothing but EOH or MeOH plus water to be sucked up by the fuel pump and into your engine. NOT GOOD. I would suggest that you stick to straight gasoline, or the 10% blend unless you have an engine developed for E85
Old Mar 7, 2008 | 03:44 PM
ground_zero298's Avatar
ground_zero298
Heres a link of some other guys that have done it, might answer some questions.
http://www.lincolnvscadillac.com/sho...highlight=fuel
Old Mar 7, 2008 | 03:53 PM
dafireman's Avatar
dafireman
I was just curious, thanks for the link groundzero.
LaredoF350
25
May 10, 2008 09:47 PM
78 Ford Guy
Offroad & 4x4
Mar 13, 2008 12:29 PM
jessman1128
Aug 10, 2005 03:50 PM
live2hunt
Jan 2, 2005 02:12 PM
silver marmot
1983 - 2012 Ranger & B-Series
Dec 18, 2003 10:07 PM
