DTC codes
Old Mar 7, 2008 | 12:56 PM
jetact's Avatar
jetact
DTC codes
I got codes P 0341 which is my PCM processor fault and P 0606 which is camshaft position sensor circut performance. What should I do. I have 37,000 mile on teh truck and have had it for just over 3 years. I also have the up a hill whistle.
Old Mar 7, 2008 | 02:25 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
You're still under the 100k warranty, I'd take it to the dealer. The whistle, are you thinking headgaskets?
Old Mar 7, 2008 | 03:02 PM
jetact's Avatar
jetact
That is what I am afriad of. I am losing coolant also.
Old Mar 7, 2008 | 03:22 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
If that IS the case, ARP headstuds are strongly suggested if the dealer has to replace your HG's. Do a search and you'll find lots of info on this, if you don't already know. Seems its best to make sure the dealer doesn't have a problem installing the studs first. I can't remember the name for where someone here got the studs for @ $450ish. Check with Tippmann on here, I think he just bought a set as he needs to get his HG's done to see where he bought them. HTH
Old Mar 7, 2008 | 03:41 PM
jetact's Avatar
jetact
Thanks D8 I will look into it.
bowldsma
1997 - 2003 F150
Jun 21, 2011 07:25 AM
kawa
Jan 12, 2008 02:13 PM
jderry78
Sep 29, 2007 07:00 PM
IM1096
Mar 29, 2007 09:02 PM
kennyruetsch
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 11, 2006 05:14 PM
