Engine Flush Add Additive
Old Mar 7, 2008 | 08:57 AM
johnsjsj's Avatar
johnsjsj
THIS LAST YEAR WHEN GETTING MY EMISSION INSPECTION TEST AND STICKER (REQUIRED IN COLORADO) I WAS TOLD BY THE HEAD ASE CERTIFIED MECHANIC THAT I SHOULD PUT IN AND RUN SOME "BG PRODUCTS - QUICK CLEAN" AND THEN CHANGE MY OIL AND THEN, PUT IN "BG PRODUCTS -- MOA (advanced formual)"
MY QUESTION IS, HAS ANYONE EVER USED THESE? WERE THEY GOOD OR BAD TO USE?
Old Mar 7, 2008 | 09:11 AM
Pocket's Avatar
Pocket
Noooooooooo don't do it. Nearly all oil additives are either 1) bad for our engines and interfere with the HEUI operation, or 2) do absolutely nothing.
Regular oil changes keep these engines surprisingly clean. Besides, no oil additive is going to help you pass inspection. Save your money!!!!!!!!!!!!!!
Old Mar 7, 2008 | 10:06 AM
VC-Racing's Avatar
VC-Racing
YES , DO NOT use it.
Old Mar 7, 2008 | 10:19 AM
RogueSpear2023's Avatar
RogueSpear2023
Another vote for don't use oil additives, if you really feel like doing something change to synthetic oil, my engine runs so much smoother now and actually will start when the temperatures go below -25 up here in the north country.
Old Mar 7, 2008 | 11:51 AM
jrciii56's Avatar
jrciii56
I agree dont do it. Most oils have a great detergency package that keep you engine clean.
Old Mar 7, 2008 | 08:30 PM
aklim's Avatar
aklim
Why not run trans fluid for a hundred miles if you have to and then drain it out.
Old Mar 7, 2008 | 09:51 PM
white Buffalo's Avatar
white Buffalo
Go back and kick the HEAD ASE CERTIFIED MECHANIC in the nuts and tell him to go find a sucker somewhere else
Old Mar 8, 2008 | 06:27 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
I totally agree, this jerk is on some kind of commision deal the the supplier of whatever snake oil he is trying to peddle. You should print this thread, and hand it to him just before you apply the medicine suggested in the above quote.
Old Mar 8, 2008 | 06:29 AM
Markadeck's Avatar
Markadeck
Would one of these 10k dollar engines actually make it 100 miles on tranny fluid in the crankcase, or is this sarcasm of the steepest kind? This is even worse than the additive salesman. Some folks on here might actually try this.
Old Mar 8, 2008 | 11:21 AM
aklim's Avatar
aklim
Sorry. Didn't mean to imply that we fill it with ATF. Just thinking a quart or two wouln't hurt provided you are just tooling around and not working the hell out of the engine.
Old Mar 8, 2008 | 11:35 AM
TchTchr's Avatar
TchTchr
I had tranny oil get into the crankcase because of a busted vacuum modulator diaphragm (a couple of quarts). Although I probably wouldn't do it on purpose, it seemed to really "clean up" the engine. I drove it 3 1/2 hours on a road trip home like this - not knowing what was going on of course. It seemed to idle and run smoother after I fixed the problem and changed the oil. Engine and tranny are doing fine - those old W123's are tough!
Old Mar 8, 2008 | 11:58 AM
IABill's Avatar
IABill
Wink
At work (City of Des Moines) we just switched to BG full syn 15-40 for the diesels and hi-lo 30 for all else cept the cops crown vics. We started this process 6 months ago using oil testing on certian diesel powered test trucks IE: snowplows & garbage packers & 6.0 strokes. on the test trucks we did use oil pretreat or flush on the test units with no adverse effects.
I like many of you have been anti snake oil from the start but after seeing the benifits to the 6.0's we have have I have changed my point of view.
We also started using the intake cleaning program for the 6.0 and OMG what an improvement we have dramatically reduced the number of EGR failuers/plugs.
Have not seen a big change in the cummins or international powered units we have flushed.
But we have had no problems with the test units yet.
B-4 switching syn we are able to start them all without using the plug in block heaters another added benifit of the full syn. prior to that if it was below 15+F and it was not pluged in it would not start.
Our goal was to dramatically extend oil change intervalls still gathering data on how far to push them out......
The above is not a BG endorsement. But just opperational observations from using the products we/I intend to continue testing as I am a skeptic at heart.
Also if we start losing motors I would be the person having to answer WHY......
Hence the 12 month impelentation timeline...Cause I like my JOB!!!
Old Mar 8, 2008 | 12:09 PM
white Buffalo
I can understand the use in your situation/application, you guys had some maintenance issues and are taking the steps to correct the problem. But, the original poster's situation was someone pushing a sale when he went in for an inspection sticker and no maintenance issue IMO. and not recommending a product because of an oil analysis report issue.
Old Mar 8, 2008 | 02:16 PM
IABill's Avatar
IABill
Question
If anyone has ANY data or information on the BG oil flush program causing failuers of any kind please forward it to me @ whvoitel@dmgov.org
As far as the tech pushing the flush sounds like a guy that gets paid by the hours he bills out.....
Old Mar 9, 2008 | 12:47 PM
IABill's Avatar
IABill
Question
Still looking for data??????
As many of you guys who were flaming flushing, one would think there is valid reason for your point of view........
