Traction Arms
Old Mar 7, 2008 | 07:34 AM
irdieforride's Avatar
irdieforride
Traction Arms
iwas wondering if any one has made Traction Arms and brackets for there truck. because i am thinking of doing it.
Old Mar 7, 2008 | 10:11 AM
blue beast's Avatar
blue beast
Are you getting axle wrap? If you lifted it and used blocks ditch them and get new
springs. http://store.summitracing.com/partde...5&autoview=sku
If it's a street truck then you probably don't have blocks and don't have to worry
about clearance issues so these would work, I do like the ones with the turnbuckles
for tension adjustment but probably isn't needed I just like the way it looks.
Old Mar 18, 2008 | 09:01 AM
irdieforride
yes ido have axle wrap and i have 4 inch blocks
Old Mar 18, 2008 | 02:59 PM
blue beast's Avatar
blue beast
Blocks put added leverage for the torque of the axle to twist the springs and really
are not worth the money they supposedly save since one good romp and too much
traction will cause you to wreck your driveshaft or worse!! Then you will be replacing
at the very least the u joints or a broken pinion etc. http://broncograveyard.com/bronco/c-472
New springs look better then the liftblocks and even those add aleafs and a smaller
set of blocks would be way better then giant 4" blocks you have now!
olmstead96
Jun 22, 2015 02:05 PM
Saber123316
May 7, 2010 06:24 PM
dvldog458
Sep 28, 2009 06:36 PM
Ranger1F150
Nov 20, 2008 10:14 AM
Button
Dec 8, 2006 06:39 PM
