Rear traction bars?
Old Aug 27, 2009 | 09:31 PM
dvldog458's Avatar
dvldog458
Question Rear traction bars?
Does anyone have rear traction arms/bars installed on their Ex?
I just had a new drive shaft made and the machinist told me I should get some rear traction aid installed for my rear spring wrap.
Do they make kits for our trucks?
Thanks,
Jerry D
Old Aug 27, 2009 | 09:35 PM
EXv10's Avatar
EXv10
Sure, there are lots out there. Just don't get ones that sit too low if you do offroading.
Old Aug 27, 2009 | 09:38 PM
dvldog458's Avatar
dvldog458
Cool!
What Brand would be the best to install?
Old Aug 27, 2009 | 09:47 PM
DCSpecial's Avatar
DCSpecial
Best working bars that won't bind the suspension and work well at eliminating axle wrap are One Up Offroad .
If you rock crawl you may not like them. I don't rock crawl so they work great on my 07 F-350
The majority of other aftermarket traction bars I've seen have design flaws that bind the suspension and/or don't eliminate axle wrap well.
Old Aug 27, 2009 | 10:19 PM
EXv10's Avatar
EXv10
I never owned any but I know there are many to choose from and many hang to low for offroading. I'm sure someone will chime in with ideas for you.
Old Aug 27, 2009 | 10:23 PM
TeamMudd's Avatar
TeamMudd
those are some massive blocks/traction bar mounts....... WOW i bet they are easily, what about........ 150lbs PER block, HAHAHA!
Old Aug 27, 2009 | 10:30 PM
EXv10's Avatar
EXv10
What mount????????
Old Aug 27, 2009 | 10:34 PM
TeamMudd's Avatar
TeamMudd
Old Aug 27, 2009 | 10:44 PM
DCSpecial's Avatar
DCSpecial
I run the OUO bolt on traction bars (not the block setup). They also have a weld on axle bracket.
Old Aug 27, 2009 | 10:58 PM
EXv10's Avatar
EXv10
Nice I doubt if they would last on the back roads around here.
Old Aug 28, 2009 | 12:37 AM
officer131's Avatar
officer131
Off the top of my head RIZE industries have a cool looking tract bar setup.
Old Aug 28, 2009 | 07:55 AM
DCSpecial's Avatar
DCSpecial
Rize may look cool.....but they do bind under certain conditions, as do other triangulated bars with a shackle mount at the frame.
Old Aug 28, 2009 | 08:35 AM
cficare's Avatar
cficare
All 4WD Excursions came with OEM snubber-type traction bars ... they are those half-leaf things in the rear spring-packs which work only when accelerating.
I just had a new drive shaft made and the machinist told me I should get some rear traction aid installed for my rear spring wrap. Do they make kits for our trucks?
Yes, and don't rule out ladder bars ... they perform the same function.
Old Aug 28, 2009 | 12:12 PM
scottf4444's Avatar
scottf4444
I bought the OUO Bolt On's from DCSpecial. A+ on the parts - A+ on the service.
Old Aug 28, 2009 | 10:58 PM
X-Hibition's Avatar
X-Hibition
cficare,
With an 8 inch lift the Devildog hasn't had the stock traction bar for some time. And it wouldn't work with any non-stock (X) spring pack.
