water pump???
Old Mar 6, 2008 | 08:55 PM
ducksr's Avatar
ducksr
Thumbs down water pump???
I have noticed a leak the past 2 days. Upon inspection it appears to be aat or under the water pump. I only lets off when off and parked. Any ideas if it is the pump? And any where to find out details on replacement? (I would like to see if this is above me or not)
Thanks
Paul
01 250cc 4x4 stock
Old Mar 6, 2008 | 09:09 PM
kellens's Avatar
kellens
If its leaking out the weephole on the bottom of the pump then its time for a new water pump.
Old Mar 6, 2008 | 09:14 PM
00Dave's Avatar
00Dave
It sounds like the weep hole is starting to leak, which is a sign of a failing water pump from my understanding. I just recently changed my water pump due to the bearings were going out. It wasn't that difficult other than getting the fan off the pump. Do a search for water pump replacement, there was a real good write-up on here. If I find it I'll post back here. If you have some basic tools, metric and standard, you should be able to accomplish this task. I purchased my pump, thermostat, therm. housing, and the upper radiator hose that goes around the belt instead of the one that goes through the belt at NAPA. Several people will recommend the billet housing for the thermostat that one of the vendors on here can supply. I agree that it would be better, I just didn't have the time to wait on it.
Old Mar 7, 2008 | 07:57 AM
ducksr's Avatar
ducksr
Thanks
Looks like tool box and 12 pack
paul.dietrich
Dec 10, 2008 09:33 PM
paulcooper1969
Apr 8, 2007 04:03 PM
Paul Welch
Apr 30, 2006 11:32 AM
sneak
General Automotive Discussion
13
Feb 3, 2005 11:53 PM
pcovington
1983 - 2012 Ranger & B-Series
May 16, 2002 05:32 AM
