Heater fix
Old Mar 6, 2008 | 01:18 PM
BaugherGarage's Avatar
BaugherGarage
Heater fix
Hi all. I wanted to pass along some info that might help others. Early in the winter I realized that my heater was NOT working like it should. I took out the heater core and radiator and took them to a local radiator shop (Leanord's North Kansas City Radiator). He pressure tested and boiled them both. The radiator checked out OK< but the heater core was plugged up beyond repair. He ordered a new core from St. Louis and swapped it over to my core body. I put it all back together and the heater is HOT. Leonard's a good-ole-boy and knows his craft. Highly recommended.
Oh, and does anyone know how to locate the valve that stops the water flow? I have a **** under the dash that pulls a cable which opens and closes a valve on the right side inner fender. The valve is rusted solid (open fortunately) ad a new valve has been added at the water pump. I'd like to get that adjustable valve replaced at some point.
Mike
Old Mar 6, 2008 | 01:27 PM
airharley's Avatar
airharley
I've seen them at NAPA. Ask to leaf through there cooling system book to find it.
Old Mar 6, 2008 | 06:10 PM
jowilker's Avatar
jowilker
I have seen all kinds of valves, ball, gate, etc. It is under the hood it is inline and it fits a 5/8in. hose.
You can use anything that will fit the heater hose.
John
Norton72
Nov 18, 2014 09:28 AM
tl1965
Jan 3, 2010 08:42 PM
guitarnik
15
Feb 8, 2009 06:53 PM
77'F-150Mudder
17
Dec 7, 2003 02:18 AM
mhjohnson48
Jan 6, 2003 06:49 PM
