pullin the piston
Old Mar 6, 2008 | 10:47 AM
tooblue's Avatar
tooblue
pullin the piston
how hard and how long. i already have the heads off. so do i take the oil pan off?
Old Mar 6, 2008 | 04:42 PM
flatlander84's Avatar
flatlander84
I don't think it's possible to pull the pan with the motor in the truck. If your motors on a stand and the heads are off, you can have your pistons out in an hour or less. Make sure the con rods and bolts don't scuff your cylinder walls and mark each set to the proper cylinder.
Old Mar 6, 2008 | 06:50 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Have you taken the heads to the machine shop yet?
How many miles on the engine?
Do you see a gouge in the cylinder wall?
My bet is valve guides and valve stems seals.
If you want to pull pistons and go that route, pull the engine.
Tear down and reassembly will be so much easier standing on flat ground.
Old Mar 7, 2008 | 06:44 AM
tooblue's Avatar
tooblue
i have these little deals that you put over the bolts when you pull the piston that way it doesnt scratch any thing.
I took the heasds to our local machine shop and he said that he thought the rings around the piston cracked and its lettin oil by. he also said i didnt need to boil or magnaflux them but i needed to have them pressure tested. I think there is 175,000 miles but there all with the pump turned up. I cant see a gouge on the cylinder wall because the piston is at the top.
Old Mar 7, 2008 | 01:10 PM
PLC7.3's Avatar
PLC7.3
Tried to PM you but you don't allow...... so PM me with an email addy for the pan removal info.....
Old Mar 7, 2008 | 01:23 PM
tooblue's Avatar
tooblue
i cant pm it wont allow. i will be pullin the pan today is there any other way i can get a hold of you.
thanks
Old Mar 7, 2008 | 03:41 PM
japf100's Avatar
japf100
Originally Posted by tooblue
i have these little deals that you put over the bolts when you pull the piston that way it doesnt scratch any thing..
I use fuel line hose over the bolts.
