1978 - 1996 Big Bronco
Engine won't stay running???
Old Mar 6, 2008 | 08:19 AM
sixty9oz's Avatar
sixty9oz
Well, I got the engine in except I can't hook up the exhaust until I get the pipes spread from 2" to 2.5", but when I start it, it dies as soon as you let go of the key? Any suggestions?
Old Mar 6, 2008 | 08:21 AM
Kemicalburns's Avatar
Kemicalburns
pull codes, check fuel pressure etc.. start simple
Old Mar 6, 2008 | 03:38 PM
sixty9oz's Avatar
sixty9oz
can you get codes if it won't stay on? We checked wiring and everything SEEMS ok with that.
Old Mar 6, 2008 | 05:00 PM
Kemicalburns
double check all the grounds. make sure they have good contact with the frame.
does it act like it loses power or not getting fuel?
Old Mar 6, 2008 | 05:06 PM
sixty9oz's Avatar
sixty9oz
It just stops immediately when you let go of the key.
Old Mar 7, 2008 | 04:35 AM
sixty9oz's Avatar
sixty9oz
Well, I figured it out. I had done some wire splicing, and gotten two wires mixed up. They were both red and one had a blue strip and one was green. It was really hard to distinguish between them. Thanks for all the help!!
Old Mar 7, 2008 | 08:14 AM
Kemicalburns
Wire splicing of what??
Old Mar 7, 2008 | 08:28 AM
sixty9oz's Avatar
sixty9oz
The wires going to the distributer. I needed to fix them, and I got the red/blue and red/green backwards. When the key was in start, it was getting power to the coil, but when it went to run, it all disappeared.
Old Mar 7, 2008 | 09:13 AM
Kemicalburns
did you solder the wires then shrink wrap them? if not you probably should so there is proper resistance.
Old Mar 7, 2008 | 12:54 PM
bertha66's Avatar
bertha66
Bad ignition switch, had one one a Tempo that the switch seperated, it would run if you turned it back a little, but held on to it, as soon as you let go, it would die.
