Sponsored by: Real Truck
Bad IDM--Again
Old Mar 5, 2008 | 06:18 PM
RV_Vagabonds's Avatar
RV_Vagabonds
Bad IDM--Again
We've just returned from the local Florida Ford dealer after having the IDM replaced along with the gasket and the under gasket wiring harness. The thing is, we had the same thing done in the state of Washington 3 years ago. The Washington techs had the error codes printed on our receipt, the Florida ones didn't.
We have a 2000 Ford F450 Superduty, with a power chip and exhaust brake. We tow a 16,700 pound fifth wheel (loaded weight) and have 132,000+ miles on the engine as fulltime rvers. This was a pretty expensive repair (double what they charged in WA) and we're wondering if there's something we can do to prevent the IDM from failing yet again. They replaced the cam sensor (free) apparently as a recall warranty part.
Original symptoms were: hard to start, hesitation, engine missing (like you had bad spark plugs on a gas engine), hard shifts, stalling, no power. We changed the fuel filter (twice), the air filter, drained the water/fuel separator thingy (yeah, I'm real mechanical), added diesel fuel injector cleaner.
I'm the distaff half of the Vagabonds
Old Mar 5, 2008 | 07:06 PM
rbaker6336's Avatar
rbaker6336
probly all that was wrong was the harness,and a possibility is had come unplugged
Old Mar 5, 2008 | 08:57 PM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE!
If you do a search on IDM you will find a lot of useful information. Often the IDM is replaced when it is not the problem.
Old Mar 5, 2008 | 09:13 PM
F350-6's Avatar
F350-6
Welcome to FTE.
I'm guessing you showed a P1316 code which states Injector Circuit/IDM codes detected.
Make sure you deal with a mechanic that understands these motors. I haven't heard of too many IDM failures unless they were getting wet. Check the spash guard (wheel well liner) above the drivers side front tire. Your IDM is hidden in there.
The more common problem is the UVCH (Under Valve Cover wiring Harness) that either comes unplugged from the connector under the valve cover, or chaffing wires against one of the moving parts under the valve cover. We have a 7.3 specific section https://www.ford-trucks.com/forums/forum31/ where you can read up on the diesel engines. Pick up an Ohm meter and keep it handy. If it happens again we can walk you through the steps using the Ohm meter to diagnose a UVCH problem. I've done that on one of my work trucks and told the mechanic "this is what I want you to do". he called back an hour later and told me he had found my chaffed wire problem.
Chris56ford
Apr 21, 2014 11:08 AM
broncobuster728
Jul 27, 2013 05:18 PM
tjbeggs
16
Mar 17, 2011 12:34 AM
dusred
63
Oct 28, 2010 12:49 PM
Kerusso
Apr 7, 2006 10:47 PM
