86 to 87 interchangeability
Old Mar 5, 2008 | 05:57 PM
rmalottwtes30's Avatar
rmalottwtes30
I have access to a set of fenders the front grill and hood from a 1987 but my truck is a 1985. I know its interchangable, but what about just the fenders and front grill or do I need to have the whole 9 yards to change it as in the radiator support and innder fenders? Im thinking if I need the inter fenders and front support it will become a BIG job since I got all that stuff sitting on the fenders and such.
My truck is a diesel would I need the front clip from a diesel? Are the radiator supports between gas and diesel the same?
Old Mar 5, 2008 | 06:34 PM
Franklin2's Avatar
Franklin2
You need the support and all the stuff underneath to change it out. You may need to do some measuring, because I believe the gasoline truck radiator support may not let a diesel radiator fit, since the diesel radiator is so big. So that will probably rule out you being able to do it.
If you had a gas truck, you just unbolt the whole front clip, and bolt it on your truck as one piece, minus the hood which goes on later.
Old Mar 5, 2008 | 07:17 PM
rmalottwtes30
So ima need to find the front clip from a diesel, because I dont want to try to make the radiator fit. haha.
Is the overall width and height of the radiator support the same as a gas, its just the opening for the radiator thats different right?
Old Mar 5, 2008 | 07:28 PM
Franklin2's Avatar
Franklin2
I am not sure, you need to measure.
Old Mar 5, 2008 | 09:13 PM
WA1986F-250's Avatar
WA1986F-250
The radiator support is definitely taller in the diesel than the gas. I have two 86's, one gas and the other a diesel. The diesel radiator support sticks out the bottom noticeably more than the gas one does.
Old Mar 5, 2008 | 10:05 PM
Franklin2's Avatar
Franklin2
That's what I was thinking, because some of the snowplow mounting kits will not fit a truck with a diesel engine. But I was not going to use this info to say he could not use the radiator support. But it makes sense.
