Leaky '94 5.0
I am constantly filling the radiator overflow container to maintain the coolant level. Overall, about half a gallon every 100 miles. There are occassional spots under the motor where I can see that there is a slow leak. I was worried that I was losing coolant because of a bad head gasket, but this problem has been around for over a year and I don't have the typical symptoms of a gasket problem. I think the leak is small, and it is probably hitting the hot engine / exhaust. I say this because I can smell the fluid cooking off on some days. I've climbed all over the engine bay and up under the truck but I can't find the source. I've replaced the radiator core, the water pump, the thermostat and both main coolant hoses. I've also replaced the small 'J' shaped heater hose that is closest to the t-stat. I don't have anything leaking into the passenger floorboard and no humidity is pumped into the cabin, so I think I can rule out the heater core. I've checked the main heater core hoses on both ends and cannot see any leakage.
One odd thing about this leak is that it doesn't seem to happen all the time. In other words, some days there will be a foot-wide puddle under the truck in the morning and most other days - nothing! I can't find any cooling schematics anywhere, so I'm not sure what cooling hoses / connections may be under the intake manifold or what could be leaky on the back (close to the firewall). I've pampered this old truck for over 150K and I keep the engine bay pretty clean, so I should be able to easily track down a leak, but I can only see the fluid that accumulates around the oil pan and front diff.
Knowing that there must be over a brazillion Ford 5.0 truck motors out there, I can't see why this problem is so unique and I haven't been able to fix it. I'm not ready to admit defeat and take it to the stealership for a pressure test. This should be an easy fix, but I just haven't gotten lucky yet. Any advice or new ideas would be greatly appreciated.
pretty sure they did away with it but I can't remember. They have steel elbows
and they can rot little pinholes through the thin metal if the coolant lost it's ability
to protect and may be the source of the leak. Mine did it so I just disconnected it
and put jb weld on it then filled it with oil and routed a hose back into itself so it
will kind of act like a heatsink and keep it from rusting more.
I would also replace the drain petcock and if you wanted to do an upgrade, Summit
carries a drain petcock that is made out of zinc so it protects the cooling system
metals cathodically, Which adds a level of protection if you run 70%water to 30%
coolant and sometimes don't change out the coolant when you should. It is a
cheap insurance item.
Does the truck make much pressure? If it does I would try and leave the cap at the
half turn so it doesn't build up much pressure and see if you still lose coolant at the
same rate!! I run a 7lbs rad cap and 70/30 ratio and I don't have overheating
problems even in august!! I use the low pressure cap since it is an old truck and I
don't want to stress my plastic end tanks and the cooling system as a whole, I even
have a rad cap that doesn't have the pressure spring and it just lets the coolant go
into the overflow tank if it gets to that point just for diagnosing I got it from a Mack
granite cab truck.
It is difficult for this old man to climb around on top of my engine (especially when it's hot) and I'm sure the neighbors get a kick out of seeing the hood up with my legs dangling over the fenders. One last note - the leak seems to be towards the rear of the engine bay, not up front near the pump / radiator. Obviously some of the leakage is blow-back, but the drainage seems to be around the starter side / area.
can be carrying the water (since the motor is tilted to the back) to the rear of the
motor and you won't see the source. If you have a piece of copper pipe just route
the tb line into itself so it takes that potential leak out of the equation.
A black light will help you find the leak since coolant glows bright green in uv light
Wally world has a small handheld flourescent black light that you can use for this
and for finding leaks in your ac and motor oil with the dyes. I bought one of the
halogen black light type leak detector kits and wish I had just went this route since
you can't leave the light on for more than 5 minutes and you have to let it cool down
and of course it is glass right there and if you get water on the hot glass (POP!!)
I would try parking so the rear end is higher and see if the leak spot moves you
may find it that way if it is one of those migrating leaks.
You have a freeze plug near that area though and is a likely leak spot
since they are just zinc plated sheet metal plugs and they can rust and
develop leaks or even get pushed out a bit and leak. buying a new set of
plugs and popping them in is pretty easy. You will see a round plug about
an inch and a half or so in diameter in the sides of your block.
Autozone.com has wiring and vacuum diagrams online for free and might
have something that would help ypou out, At least you could always look
for websites with pics of your motor and then enlarge the pics.
I guess I'm disappointed in the old girl because she's been pampered for so long, only to develop this crack. I'm not sure why the crack formed in the first place, other than some form of 5-liter osteoporosis. I love the truck - like a pair of old blue-jeans. Unfortunately I don't know how much longer she'll hold together. I guess the same could be said about me.
Anyway, is there anything JB weld can't fix?
