351W/miss
Old Feb 15, 2002 | 04:58 PM
pademc's Avatar
pademc
351W/miss
I have a 79 351W with a new Edelbrock 600 CFM w/electric choke, a Borg-Warner 4 Speed, and a new single point dist. with a vacuum advance, new plugs, points, rotor, cap, and wires. I also have a miss at all speeds. At an idle, if I remove the vacuum line from the carb, the miss goes away. It also happens at any increase in rpm's. I tried to adjust the timing, but it still happens. Also no change when I try to adjust the idle mixture screws on the carb. Also no plugs are fouled. I have about 5000 miles on the engine since I put it all together and the problem has been around for the last 500 miles or so. Any ideas what I can look for to find this miss? Any and all help would be greatly appreciated.
Dennis McClellan
Mesa AZ
48 F1 351W w/Borg Warner 4 speed
Old Feb 15, 2002 | 06:31 PM
Bill_Beyer's Avatar
Bill_Beyer
351W/miss
You might want to try posting this in the 351W forum.
Old Feb 15, 2002 | 08:56 PM
Mil1ion's Avatar
Mil1ion
351W/miss
