Aluminum Heads?
Old Aug 6, 2001 | 01:31 PM
danlee's Avatar
danlee
Aluminum Heads?
Does anyone have any information on a source for Aluminum Heads for 351C/351M/400 engines?
Old Aug 7, 2001 | 09:54 AM
bsprowl's Avatar
bsprowl
Aluminum Heads?
Try looking in the ads in the back of magazines such as Muscle Mustangs.
Bob
'66 7 Litre, top loader, 3.25 Traction-lock, Sidewinder Intake, SCJ Exhaust
'88 F150 LWB 4x2, XLT Lariat, 302, 5 speed, 3.08
'99 Ranger, 4x2, 3.0, 5 speed, 3.73 posi
Old Aug 7, 2001 | 05:17 PM
stryder's Avatar
stryder
Aluminum Heads?
I know Yates makes an aluminum head, but I think its for racing only....Not to mention you had have some serious $$$$. I think they go for 2-3k, but not for sure.
Stryder
I'd rather be walking through a hot desert carrying a Ford hubcap than driving a POS Chevy
Old Aug 7, 2001 | 05:42 PM
Bill_Beyer's Avatar
Bill_Beyer
Aluminum Heads?
The Yates head is designed for W blocks...and no it's not a street head.
Old Aug 8, 2001 | 10:16 AM
beartracks's Avatar
beartracks
Aluminum Heads?
I believe Ford Motorsports used to offer a 4v in aluminum but even if you found one it would have huge ports.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Aug 11, 2001 | 07:06 PM
Boss_358's Avatar
Boss_358
Aluminum Heads?
[font size="1" color="#FF0000"]LAST EDITED ON 11-Aug-01 AT 08:07 PM (EST)[/font][p]Motorsport does not make much of anything for the cleveland anymore. There is only one place I can think of that makes aluminum heads for the cleveland and they are as much as the yates head. I think the name of the company is blue thunder but I am not sure. My brother knows and I will find out from him whenever I can find the guy. He's in the prime of his partying youth and is hard to track down sometimes.
EDIT: The comapany does advertise in the back of muscle mustangs as well as a couple of other ford based performance magazines.
People who say it can't be done should not interrupt the person doing it.
Old Feb 8, 2002 | 06:55 AM
shazam's Avatar
shazam
Aluminum Heads?
Old Feb 19, 2002 | 09:51 AM
MrMotorsport's Avatar
MrMotorsport
Aluminum Heads?
Take a look at the Brodix BF300 or BF301 heads. They are a high-port head designed to be used with Cleveland pistons (valves in these heads use the appropriate valve angles, unlike the Yates, which require unique, and expensive, pistons) on 335-style blocks (or Windsors, just drill the appropriate coolant holes) These are not a huge, lazy-flowing "4v-style" port, either. The ports on these heads are relatively small resulting in extremely high velocity (great for torque) I am running a set and am very pleased with the results. They even list the flow figures so you can plug them into your Desktop Dyno..... Check them out at www.brodix.com - Don
Old Feb 19, 2002 | 10:56 AM
Fastcat's Avatar
Fastcat
Aluminum Heads?
Blue Thunder does make an aluminum head but it's designed for racing. You can call Blue Oval in Denver and talk to Rob. He'll know all about it. He might know some other sources too.
Blue Oval
303-762-8298
Old Feb 19, 2002 | 06:59 PM
Big Blue4x4's Avatar
Big Blue4x4
Aluminum Heads?
If you happen to have about $5 grand laying around, and who doesn't, these Arao Engineering Aluminum 4 valve Cleveland heads will do just fine.----->http://www.araoengineering.com/Ford/clevelnd.htm
Wanted: Winch for pulling out Chevys!
79 F150 4x4 410m built!(9.1:1,KB pistons,custom Comp Cams X-Treme 210/218-.508/.524,roller rockers)/c6/3.5:1 gears,4.11:1 soon, Demon 4bbl, 285/75R16 BFG Mudders on alumn. mags with New Drk. Blue paint.
65 Ranchero 170-6, 3on the tree, solid mags, New Bright Yellow paint
Old Feb 19, 2002 | 09:53 PM
xyfalcon500's Avatar
xyfalcon500
Aluminum Heads?
there was a thread a few months back that had a post about an alloy '3V' head which is made here in Australia... have to check the post to find the info... I think the thread is labelled 'somebody finally stepped up...'
It is an alloy head which uses 4v valves and fits 4v intake and exhaust manifolds, but has port runners smller than 4v's an bigger thn 2v's.
Old Feb 21, 2002 | 01:31 AM
blu93gt's Avatar
blu93gt
Aluminum Heads?
i saw a pair of the motorsports heads on ebay a couple months ago - i think they were called "a3" or something. very expensive. looked a lot like a yates head, but i think it was from the early/mid 80's and had the boss302/cleveland valve angles.
