Buildup!! 06 crown vic front suspension into 67 F100
Old 11-07-2011, 09:03 PM
elgemcdlf's Avatar
elgemcdlf
elgemcdlf is offline
If you are doing this in a bump you will need to notch the frame.
  #1322
Old 11-07-2011, 09:09 PM
Sprout22's Avatar
Sprout22
Sprout22 is offline
its goin in a 70 f100. thx for clearin that up, i kno its a rack n pinion, i just had a brain fart at the time. lol
  #1323
Sprout22's Avatar
Sprout22
Sprout22 is offline
what is a bump? lol
  #1324
Old 11-07-2011, 09:13 PM
elgemcdlf's Avatar
elgemcdlf
67-72 Ford pickup. Got the name from the protrusion along the side of the body. 73-79 are dents. Is a flipped solid axle your final rear configuration?
  #1325
Old 11-07-2011, 09:14 PM
Sprout22's Avatar
Sprout22
Sprout22 is offline
here's my 70. Got it a few months ago. Floor of bed is rusty and the rear of the passenger bedside is full of bondo. I would like to find another bed but they are hard to find around here.
  #1326
Old 11-07-2011, 09:15 PM
elgemcdlf's Avatar
elgemcdlf
Where are you located? I can get you a bed in NV. Nice looking truck.
  #1327
Old 11-07-2011, 09:18 PM
Sprout22's Avatar
Sprout22
Sprout22 is offline
oh ok gotcha. For now thats what I gotta do to the rear. I would love to put IRS but dont hav the money.
  #1328
Old 11-07-2011, 09:19 PM
Sprout22's Avatar
Sprout22
Sprout22 is offline
i live in NC
  #1329
Old 11-07-2011, 09:25 PM
elgemcdlf's Avatar
elgemcdlf
I may be able to get it as close as Ohio next year. The reason I ask about the rear end is once you notch it you are pretty much stuck with replacing the frame if you want to do the IRS later. Well unless you rebuild the area you are about to remove. Take a look at JG F100 for his thread. I think he flipped an explorer axle in his.
  #1330
Old 11-07-2011, 09:28 PM
Sprout22's Avatar
Sprout22
Sprout22 is offline
ok thx dude. ill let u kno on the bed. And ill look at the post as well. thx again. BTW, your truck looks great.
  #1331
Old 11-09-2011, 11:01 AM
Sprout22's Avatar
Sprout22
Sprout22 is offline
Is the 96 CV rear end the same as the 97 that everyone is using? I found a 96 I can get pretty cheap
  #1332
Old 11-11-2011, 11:42 AM
jeff gammon's Avatar
jeff gammon
jeff gammon is offline
elgemcdlf, could you post a pic of your engine mounts? I dont understand how you did yours. I have looked at several and thay all look like good ideas, but am always looking for a better way. Mine will also have a winsdor in it.
Thanks,
Jeff
  #1333
Old 11-16-2011, 09:49 AM
jeff gammon
I have spent hours and hours researching this swap, and dont understand why the 03 up front end will fit, but the 03 up rearend is to wide. They must be the same width. I would be grateful for any help. I will be using 05 up mustang bullitt wheels on mine, I have read they have the same offset as the org. crown vic wheels
  #1334
Old 11-16-2011, 06:24 PM
chirvs's Avatar
chirvs
chirvs is offline
Originally Posted by Sprout22
i live in NC
Not too hijack,but I'm in SC on the NC border.Ck craigslists. alotta bump parts show up there.
  #1335
Old 11-16-2011, 08:17 PM
pidaster's Avatar
pidaster
pidaster is offline
I thought the problem was that the pumpkin was off center on the newer rears.
Quick Reply: Buildup!! 06 crown vic front suspension into 67 F100
