Shimmie
Old Mar 4, 2008 | 07:57 PM
Flip4ford's Avatar
Flip4ford
Shimmie
Seems my Exploder Lucille "Lucy" has always had a shimmies at the 65-70 MPH range... a lot of research has netted the following "Cure"
<TABLE cellSpacing=2 cellPadding=1><TBODY><TR vAlign=top><TD>1.</TD><TD>Raise and support the vehicle. </TD></TR><TR vAlign=top><TD>2.</TD><TD>Loosen, but do not remove, the powertrain/drivetrain mount fasteners. </TD></TR><TR vAlign=top><TD>3.</TD><TD>Lower the vehicle. </TD></TR><TR vAlign=top><TD>4.</TD><TD>CAUTION</B> : Do not twist or strain the powertrain/drivetrain mounts.
Move the vehicle in forward and reverse (2-4 ft).
</TD></TR><TR vAlign=top><TD>5.</TD><TD>Raise and support the vehicle. </TD></TR><TR vAlign=top><TD>6.</TD><TD>Tighten the powertrain/drivetrain mount fasteners. </TD></TR><TR vAlign=top><TD>7.</TD><TD>Lower the vehicle. </TD></TR><TR vAlign=top><TD>8.</TD><TD>Test the system for normal operation.</TD></TR></TBODY></TABLE>
Anyone ever heard of this, done this, or even thinks it might work?
Just looking for opinions.
Old Mar 4, 2008 | 08:09 PM
husker's Avatar
husker
We had a 94 sploder that developed a shimmie and I tightened the large nut(not the one behind the steering wheel) on the front spindles because of some wear in the front wheel bearings and that solved most of the problem. There was some play at the wheel. I didn't have to replace the bearings, just repacked them while things were apart.
Old Mar 4, 2008 | 08:15 PM
HappyJack's Avatar
HappyJack
First thing I did to Green was have the motor mounts replaced. That little 4.0 just seemed to move around a bunch. But they weren't that bad. So if I understand what is ment that you need to loosen the front and rear (tranny) engine mounts and move it forward and back to align the engine and tranny then tighten the mounts?
Old Mar 4, 2008 | 08:17 PM
HappyJack's Avatar
HappyJack
Thats a good idea. How long has it been since you checked the front wheel bearings?
Old Mar 4, 2008 | 08:21 PM
Garden Spyder's Avatar
Garden Spyder
He percussion checked the drivers front on the way to Colorado in Aug. when he lost his front wheel.
Old Mar 4, 2008 | 08:25 PM
fordnut1985's Avatar
fordnut1985
Some times that little trick works but you have to push the vehicle by hand not drive it. I wtill say pull the driveshaft and I will spin it and see if it is out of balance. Worst case scenario we can throw it on the dyno and try and track it down that way.
Old Mar 4, 2008 | 10:08 PM
Flip4ford's Avatar
Flip4ford
It was just a thought.. I just did a little web searching.
I don't think it is the wheel bearings because it has always had it... even when Mark owned it.. and think of all the things that have been replaced since then...
Old Mar 4, 2008 | 10:36 PM
kbkathri's Avatar
kbkathri
My vote is for the dino thingy majig. Sounds pretty technical, and Duane knows what he might know what he is talking about.
(Still should have went bed, more scotch....LOL).
Old Mar 5, 2008 | 08:07 PM
fordnut1985
I think you need to put the scotch down ifn' you think I know what I'm talking about lol. I just fake it real well.
Old Mar 5, 2008 | 08:35 PM
HappyJack's Avatar
HappyJack
Yup put the scotch down and replace it with bourbon sippin whiksey. Sounds good I'm off to the kitchen now.
Old Mar 6, 2008 | 07:06 AM
Flip4ford's Avatar
Flip4ford
Great I'm asking shaking advice from a bunch of drunks.... ha ha ha ha
Old Mar 6, 2008 | 11:51 AM
mikebon08's Avatar
mikebon08
Sobriety is good but, like everything else, in limited doses.....
Old Mar 6, 2008 | 04:38 PM
fordnut1985
Now come on dude, you knew what you were getting into before you even posted lol.
Old Mar 6, 2008 | 07:16 PM
Flip4ford's Avatar
Flip4ford
Actually this is about 70% milder then I was expecting - No pelvic thrust comments, or Hunka Hunka burning truck....
vloney
6.7L Power Stroke Diesel
Nov 2, 2013 09:56 PM
afonda
Jun 30, 2009 01:12 PM
96_4wdr
Aerostar
Mar 5, 2008 02:09 AM
chaparro
Feb 15, 2007 11:18 PM
