IC boots and tubes question.
Old Mar 4, 2008 | 04:22 PM
pullinair's Avatar
pullinair
I am shopping around for IC boots for the entire system. What do you think about the BD power clamps?
http://shop.ivalueinternet.com/shopd...ct_id/1552.htm
And does any one have any good IC tubes that they would like to sell? I bent mine due to overtorqueing them . They are crimpled on the end. I also going to take my IC to the radiator shop to get pressure tested and cleaned.
Old Mar 4, 2008 | 05:00 PM
dave at BD Power's Avatar
dave at BD Power
Former Vendor
Our 7.3L BD spring loaded clamps do work good with the factory boots if the tubes are cleaned correctly. Because the crank case vents through the intake pipe oil gets sucked through the turbo and pushed through the intercooler so oil gets onto the tubes which causes them to slip off, once they come off they hard to get them to stay on.
Tip: Clean the tubes with a brake cleaner and spray them with hairspray after they are clean.
Most of you probably know this information already but what most of you probably do not know is we have almost completed our BD Cranks Case Ventilation Kit that will eliminate this problem all together. Release Date is targeted for later this month. Sign up for the BD E-Newsletter and never miss another BD product release! This month we are giving away a free X-Flow Intake Adapter. Click here for more details.
Old Mar 4, 2008 | 05:25 PM
pullinair's Avatar
pullinair
so it is just the clamp, not the hoses?
Old Mar 4, 2008 | 05:33 PM
Alpine6's Avatar
Alpine6
Yeah.. looking at the ad, it looks like its the boots too. That's a quite a bit of coin just for clamps. New engine boots (IC's and Spider) w/ clamps for $99 @ Dieselsite. If the BD was for clamps and boots, that'd be a great deal!
Old Mar 4, 2008 | 05:34 PM
dave at BD Power
Former Vendor
That's correct, just the clamps, we are having troubles finding the size we need in the heavy duty silicon boots.
Old Mar 4, 2008 | 05:38 PM
dave at BD Power
Former Vendor
Not sure what ad you are looking at? our clamp kits sells for about $50.00US
Old Mar 4, 2008 | 05:46 PM
Alpine6's Avatar
Alpine6
the ad the OP posted:
Looks like it includes two spider boots and then two "reformed" IC boots.
Old Mar 5, 2008 | 09:52 AM
dave at BD Power
Former Vendor
I will have to contact them, that is definitly the kit for the Cummins they are advertising.
Old Mar 5, 2008 | 11:53 AM
DieselCamper01's Avatar
DieselCamper01
I disagree. I think that this kit is for the clamps only. It says it is an upgrade to your "existing" boots.
Old Mar 5, 2008 | 12:00 PM
dave at BD Power
Former Vendor
I agree, but the picture shows the boots from a cummins.
Old Mar 5, 2008 | 12:11 PM
DieselCamper01
Just using a "one size fits all" picture maybe?
