Does this sound like a good engine
Old Mar 4, 2008 | 12:50 PM
68bluebeast's Avatar
68bluebeast
I found this ad on craigslist. DO you guys think it sounds like a good engine to have to rebuild for my 68 f-250? my truck has a tired 360 and a good automatic C6 which I would be using on the new engine. What questions should I be asking the guy? http://salem.craigslist.org/pts/580874937.html
Old Mar 4, 2008 | 02:45 PM
68bluebeast
he wants $300 for it
Old Mar 4, 2008 | 03:01 PM
60F100's Avatar
60F100
If I were closer I would probably jump on it, but I live in Florida. I would check it out first.
Old Mar 4, 2008 | 03:16 PM
country0001's Avatar
country0001
If it ain't rusted out its worth 300, just in parts. I'd jump on it no matter what.
Old Mar 4, 2008 | 05:38 PM
jowilker's Avatar
jowilker
There is a good chance that his engine is a 360 also. My recommendation is that you rebuild what you have if you can be without the truck for 2-3 weeks.
John
Old Mar 4, 2008 | 10:52 PM
68bluebeast
My engine cannot be rebuilt
Old Mar 5, 2008 | 04:21 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Do not buy the engine without measuring the stroke.
All FE engines look identical. 360 stroke: 3.50" / 390 stroke: 3.78"
Ask to see the receipts for the engine rebuild. To some ppl, an engine rebuild means valve seals and a paint job.
While there's no guarantee what the engine NOW is, the original VIN engine codes (4th digit) for a 1973/76 F100/350 are: H = 390 2V / M = 390 4V / Y = 360 2V
Old Mar 5, 2008 | 05:50 AM
jowilker's Avatar
jowilker
While I don't disagree with Bill da Dummy, a 74 should have hardened valve seats. Look between the two center spark plugs for a number that starts D2TE or DT3E Being able to hear it run would be a plus. If the motor is running without knocking or smoking, $300.00 or less is not a bad price if yours can't be rebuilt. Try talking him down to $250.00 if you can, but go prepared to bring it back. (unless you live close by and want to check him out)
While it can be a 390 a 360 is more likely, but if you need a motor........
John
Old Mar 5, 2008 | 09:08 PM
The R2's Avatar
The R2
i am in the middle of rebuilding a fe motor and i thought i had a 390 and now i think its a 352 or 360 anyway i have spent 1100 dollars rebuilding and counting..so if someone is selling a motor that was rebuilt only 20ish thousand miles ago and is only asking 375 for motor and truck i would really have to stop and ask why so cheap after spending that kind of money.
Old Mar 6, 2008 | 03:29 AM
jowilker's Avatar
jowilker
It could be because his mommy or wife told him to get the crap out of her sight, and like right now.
John
Old Mar 6, 2008 | 12:02 PM
GLR's Avatar
GLR
Did you ever notice that most FE engines become 390's when people are selling? It's not too bad a price for engine and trans.. Most junk yards figure 1$ per cubic inch. Check it out closely, if it's still in truck, can you hear it run, do a comp check pull a valve cover etc. This would be if you are thinking about just dropping it in without rebuilding.
Old Mar 6, 2008 | 12:07 PM
wedefyu's Avatar
wedefyu
Sometimes you get lucky too, I recently found a 390/4spd/205xfercase all bolted together in a hi boy frame from my local junk yard for $375, motor turns over nice but probably needs rebuilt. It was a good deal.
Old Mar 8, 2008 | 09:05 AM
DarkWolf40's Avatar
DarkWolf40
Yes, but most people rebuild thier 360's into 390's.
Old Mar 11, 2008 | 06:26 AM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
impossible to tell 390 and 360 apart unless you meausre stroke, i would jump right no that though, if your motor isnt rebuildable, then i would hop all over this deal, as it will bolt directily to your trans, if its a 390 or a 360, either way. Also i would ask for recipts for the rebuild, no recipts then offer him 250 for it, as he has no proof of the rebuild.
