351m/400 pistons???
Old Feb 26, 2002 | 10:32 PM
teamwizard's Avatar
teamwizard
Post 351m/400 pistons???
hey guys, im fixing to pull my engine out this week to send it out to the machine shop. can ya'll give me some advice on a cam.to use-my truck will be used for off-road, some towing, it will rarely see the highway. what pistons are good to use with the 400. i hear alot of talk on Ohio Pistons, but i cant find anyone who sells them. what other choices do i have with pistons to get my compression up.
thanx gabriel
Old Feb 28, 2002 | 01:11 AM
mtflat's Avatar
mtflat
351m/400 pistons???
I have one I need to rebuild as soon as the weather breaks and spring comes - should be about June.
I plan to use a Comp cam in the 268H grind. Jegs has a listing and pn for 351M/400's
I only have info I've copied from other sites, so it might be worth all of what it costs you - lol Ohio Pistons also sold under Badger, Nylen and Ertel brand names. For the 400, the pn is 400-100F. Ph # 626 869 0270
I don't know who or what this connects you to - not much help I realize, but I was just going to get on the phone and see where it leads. If you go this route, I'd appreciate any info on your success.
Tim
Old Feb 28, 2002 | 08:04 AM
teamwizard's Avatar
teamwizard
thanx for the info Tim, i'll let you know what happens!
Old Mar 2, 2002 | 03:33 AM
GT40man's Avatar
GT40man
351m/400 pistons???
you can try paw for them, or your engine builder should be able to get them. or you can use 351c pistons and bush the rods for the pins to fit. once again the engine builder knows the way.
Old Mar 6, 2002 | 03:58 AM
Torque1st's Avatar
Torque1st
Posting Legend
The Ertel part number is 1282P for a flat top cast 400 piston that will get you about 9:1.
Phone numbers I have:
OHIO PISTON & PIN CO. 317-636-3531
ERTEL PISTONS 800-428-4591
Old Mar 6, 2002 | 07:49 AM
shazam's Avatar
shazam
351m/400 pistons???
