thermostat housing
Old Mar 4, 2008 | 11:09 AM
Okiedokie's Avatar
Okiedokie
thermostat housing
Can anyone provide me with an application for the housing on this motor? I need the 90 degree angle and the threaded bung for a sender. Thanks, Joe.
Old Mar 4, 2008 | 09:12 PM
Boba Fett's Avatar
Boba Fett
Summit Racing, 90" Housing for small block Ford. Do not get chrome.
I think that is a 64-68 Mustang Thermostat Housing...... but not sure
Old Mar 4, 2008 | 09:54 PM
Okiedokie's Avatar
Okiedokie
Thanks, I will look at Summit.
Old Mar 4, 2008 | 10:01 PM
Okiedokie's Avatar
Okiedokie
I could not find on Summit, found 90,s, not with bung for sender.
Old Mar 5, 2008 | 06:02 AM
baddad457's Avatar
baddad457
Your local parts house stocks these. look for a 79-95 Mustang 5.0 housing.
Old Mar 5, 2008 | 06:15 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The 1962/67 221/260/289 t/stat housing (C3OZ-8592-A) is a plain jane-no threaded hole.
1968 and later is the type you want...there are (at least) three different ones.
C9OZ-8592-A ~ 1968/86 passenger cars 302/351W (except 1979/95 Mustangs)
D5ZZ-8592-A ~ 1975/78 Mustang II 302
D5TZ-8592-A ~ 1973/96 F Series trucks with a 302. Also used on 1979/95 Mustangs.
The same t/stat housing gasket (C3OZ-8255-A) is used on all.
Old Mar 5, 2008 | 03:53 PM
baddad457's Avatar
baddad457
Advance Auto Parts: two housings in stock, "Factory Air" # 84884 & Stant # 31418 $15-16 each.
Old Mar 6, 2008 | 02:06 PM
Okiedokie's Avatar
Okiedokie
Well baddad, they appear to be similiar, although not the same. I will take a look.
Bill, I have an 84 mustang housing now, it is not threaded for a sender. Thanks guys, Joe
Old Mar 6, 2008 | 07:15 PM
baddad457's Avatar
baddad457
They're made by two different companies, but both fit the same applications.
Old Mar 7, 2008 | 09:16 AM
Okiedokie's Avatar
Okiedokie
Well, I meant that they are different from Ford Racing crate motor. the one that Advance has is threaded in such a manner that the sender for the electric fan I have installed would prtrude into the thermostat itself. the one on the FR motor has a raised bung that should place it above the stat. Make sense? They are both 90 degree housings, but the threaded bung is completely different.
Old Mar 7, 2008 | 05:43 PM
baddad457's Avatar
baddad457
I see what you mean now, I never paid attention to the pics as far as that aspect went. In any case, the application is a 87-93 Mustang 5.0 H.O., plus a few others.
fordguy2100
Ford Truck Parts for Sale
May 13, 2016 10:37 AM
bjmayberry2
Feb 26, 2016 04:37 PM
lesh11
Sep 3, 2015 01:38 AM
mando jake
Mar 24, 2008 08:13 AM
JJR
Jun 23, 2001 10:06 AM
